GARAGE SALE, everything must GO! Tranny parts, ED parts, ETC...
It's time for me to clear out some of my extra parts, let me know via PM if anything interests you, no reasonable offer refused, parts must be gone. Extra pics upon request. Parts are in Pennsylvania.
1999 Civic EX Transmission Part-out.
Transmission had an input shaft bearing failure, All parts are for sale, or buy em all if you wish, name a reasonable price for anything you are interested in, including the case halves. All parts are still serviceable.
Needs New ISB, Countershaft snap-ring bearing, and new seals. 2nd gear blocking ring is worn down, all others are plenty good.
1994 Civic DX Transmission Part-out:
Transmission also had an input shaft bearing failure, and the case was damaged but all other parts are still good.
VSS is broken
No backup light switch
No Bearings
No Case
1991 Civic DX Distributor.
Needs shaft seal (leaks oil) but works just fine, has new cap and rotor.
2000 Civic EX ECU.
Pulled for a B16 swap, and is in excellent shape.
1991 Civic DX Head Unit.
Original Head Unit, in excellent shape.
1991 Civic DX Cluster.
Came off my new car, and all gauges work, was pulled for one with a tach in it. Needs a few bulbs.
1991 Civic Si Throttle Body.
Has MAP and TPS on it.
1991 Civic Si IACV.
VSS is broken
No Bearings
No Case
2000 Civic EX ECU.
1991 Civic Si IACV.
