HELP!! B18B1 OBD1 SWAP in a OBD2 97 EK CIVIC HELP!!!
Old Nov 22, 2007 | 02:52 PM
gotboosthatch's Avatar
Default HELP!! B18B1 OBD1 SWAP in a OBD2 97 EK CIVIC HELP!!!
hey guys, ive been checking on here for about 5 hrs and cant find the answer to my question and was wondering if you guys could help me out.
im doing a obd1 b18b1 swap in a 1997 obd2 civic dx and i need help on what to do with the wiring.
im pretty sure you have to rewire the injectors,dizzy,and alternator plug but I dont know what wires to or what to do with them.
Also i have a obd2a-obd1 jumper harness for the ecu.
can anyone please help me out and point me in the right direcion on what to do.
thanks in advance. i really appreciate it..
Old Nov 22, 2007 | 05:43 PM
anyone?
Old Nov 22, 2007 | 05:54 PM
abusedhusband's Avatar
Default Re: HELP!! B18B1 OBD1 SWAP in a OBD2 97 EK CIVIC HELP!!! (gotboosthatch)
just use your stock injectors and alternator from the 97. you will have to get a dizzy tho. everything else should plug up with no problems if the car is a manual trans ex model. if not you will have to do the IAC wire fix,and crank sensor wire fix. you will also have problems with inspection. put a 0bd2 oil pump, crank sprocket for the timing belt, and crank sensor and you should be ok. just swap plugs from the sohc crank sensor with a ls one. im pretty sure thats it.
Old Nov 22, 2007 | 06:37 PM
its a 1997 civic dx... isnt there a way i can rewire the dizzy instead of buying a new one.. i still have the stock d16y7 motor..
also can you send me a link on to how to rewire different things i need too.. thanks a lott
Old Nov 22, 2007 | 06:55 PM
prettylew's Avatar
d series and b-series distributors are totally different, if you cant afford a used dizzy or a new one, then perhaps you arent ready to do a motor swap
Old Nov 22, 2007 | 07:23 PM
this swap is for my friends car.. ill have to see how much his budget is.. i have a b series obd1 dizzy and want to know how to convert it to obd2 not using a d series on a b series ???????
Old Nov 22, 2007 | 07:44 PM
prettylew's Avatar
conver the dizzy harness from obd 1 to obd2!!!!!!!!!!!!!!!!!!
Old Nov 22, 2007 | 07:48 PM
Jbur074's Avatar
if you have the bseries dizzy, all you have to do is rewire it from an obdI to obdII, requires cheap solder and a soldering iron.. you dont need a new dizzy.. just make sure you get the right one or it can fry your ignition module..
Old Nov 22, 2007 | 08:11 PM
thanks man, what about the injectors and the alternator plug?
Old Nov 22, 2007 | 08:13 PM
prettylew's Avatar
the FAQ section at the top of this forum is YOUR FRIEND. i use it at least twice a day. lol.
check this article. should answer alot of your unanswered and un thought of questions
https://honda-tech.com/zerothread?id=1972711
Old Nov 22, 2007 | 08:15 PM
prettylew's Avatar
and i dont know if you know this, but if you HATE reading a big article online and just wanna search for a keyword(s) then hold down CTRL and hit the F key and a lil search window will pop up and it will search whatever page your on for the word you type in
Old Nov 22, 2007 | 09:06 PM
sweet thanks man
Old Dec 3, 2007 | 09:56 PM
StreetEG's Avatar
Hey i purchased a P28 off you on november 23rd and i still havent received it yet? I PM'd you and emailed you and still nothing....
Old Dec 9, 2007 | 04:20 AM
hatchback freek's Avatar
Default Re: HELP!! B18B1 OBD1 SWAP in a OBD2 97 EK CIVIC HELP!!! (StreetEG)
did you use that same diagram to make the conversion harness?
Old Feb 23, 2015 | 10:00 PM
HondaCRZY's Avatar
I have a B18B1 in my car and i get 250km per tank of gas.
Is the timing too advanced or is it the O2 sensors?
This car was converted to OBD1 from OBD2
Koofy23
May 11, 2015 05:14 PM
EG6_LS_BOOST
Aug 22, 2013 11:05 PM
civicb1812345
Dec 21, 2012 07:17 AM
isaacson06
Jun 29, 2007 02:52 PM
