******* How to get rid of seam sealer .. rust underneath *******
Old Nov 22, 2007 | 02:44 PM
misaelmelchor's Avatar
Default ******* How to get rid of seam sealer .. rust underneath *******
Hello fellas... i was stripping the whole back of my car.. took of all the panels and seat and basically stripped down... As i was cleaning up everything, i saw rust spots by the bottom wheel well floor pan... There is a seam sealer over it and how do i get into tight spaces... I was planning on using wire brush ... any thoughts or ideas on how to approach this? thanks
Old Nov 24, 2007 | 03:13 AM
so many views but no replies?
Old Nov 24, 2007 | 04:26 AM
Disease's Avatar
Default Re: ******* How to get rid of seam sealer .. rust underneath ******* (misaelmelchor)
They sell a wire brush specifically for this but a regular wire brush will not work as good. They tend to heat it up and the sealer clogs up the brush. I usually use a heat gun and a scraper and it all comes right off. Then you can use the wire brush for the little bit of left over.
http://www.snapon.com/Internat...g.pdf
Quick search showed this pdf of a snapon tool that works great. You can see the difference in the wire brush that you would normally have and they type that this one comes with. If they sell a wire brush for your tool like that one then I would get it cause it would save so much time.
Old Nov 24, 2007 | 02:02 PM
InlineS13's Avatar
Default Re: ******* How to get rid of seam sealer .. rust underneath ******* (Disease)
Just go to Sears and get a wire brush attachment for your drill or something and go to town. Works great for me.
Old Nov 24, 2007 | 03:27 PM
thanks guys
Old Nov 24, 2007 | 05:47 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: ******* How to get rid of seam sealer .. rust underneath ******* (InlineS13)
wire wheel on angle grinder + heat (propane torch) =
i drive a honda
Honda Motorcycles
10
Jan 13, 2009 05:16 PM
batboyvaj
Welding / Fabrication
Jan 16, 2008 02:20 PM
supercreed2002
Mar 15, 2006 09:45 AM
AllmotorEH2
Feb 28, 2005 08:48 PM
