buddy club III and smog
i ran a search but none of the threads had a conclusive conclusion. Anybody with experience passing smog with BC III's? Also, how easy is it to pass smog with ITR cams. I read that you can easily fail with ITRs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">i ran a search but none of the threads had a conclusive conclusion. Anybody with experience passing smog with BC III's? Also, how easy is it to pass smog with ITR cams. I read that you can easily fail with ITRs.
Your reading false information. Stage 1 skunks are smog legal in california, so how are ITR/CTR cams going to make you "easily fail"... BS. I've passed emissions with both.
</TD></TR></TABLE>Your reading false information. Stage 1 skunks are smog legal in california, so how are ITR/CTR cams going to make you "easily fail"... BS. I've passed emissions with both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">
Your reading false information. Stage 1 skunks are smog legal in california, so how are ITR/CTR cams going to make you "easily fail"... BS. I've passed emissions with both.</TD></TR></TABLE>
Exactly, ITR/CTR cams are STOCK cams so common sense would tell you they won't cause you to fail smog on their own. Typically if you run a cam with stock like primary lobes, it won't affect your smog outcome. If you do fail, it means you have other problems.
True i passed state ref smog test w/ ITR pistons and bc3 cams in my gsr
But i failed MIL or CEL test cause i gots a P0301 cylinder 1 misfire code
nokturnal_munkeeboy
Jun 3, 2007 10:42 AM
is3oo
Mar 2, 2005 01:05 PM
