swaping rails and brackets
Old Nov 22, 2007 | 03:57 AM
die_lawn's Avatar
Default swaping rails and brackets
how do i take brackets from my EK seats and put them on Del-Sol seats. it looks like i need to take the plastic off but i don't wanna pull the wrong thing off and not be able to get it back on. is there an easy way to do it?
Old Nov 22, 2007 | 05:57 AM
Phil_Eg's Avatar
Default Re: swaping rails and brackets (die_lawn)
The brackets might now bolt up correctly because the bold pattern is different.
Old Nov 22, 2007 | 06:53 AM
SMOOTHN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil_Eg &raquo;</TD></TR><TR><TD CLASS="quote">The brackets might now bolt up correctly because the bold pattern is different.</TD></TR></TABLE>
Yes you might have to drill the bracket to fit onto the seats or you can bolt in 3 bolts and the last bolt that is off you can make a adapter plate from a piece of metal
Old Nov 22, 2007 | 02:43 PM
die_lawn's Avatar
ok, so i might just have 3 bolts that are gonna be in the ground or the seaT?
Old Nov 27, 2007 | 08:59 PM
SMOOTHN's Avatar
you lost me? if you decide to use just 3 bolts it might be kinda wobble at turns and stops... adding a steel plate to the last mounting hole will stop that wobble..
PreyStayShun
Nov 26, 2011 05:07 PM
vtec.dc2
Nov 20, 2004 01:57 PM
Hatchtrap
Oct 29, 2004 04:32 PM
Mr. Bagel
Honda S2000
Sep 22, 2004 12:47 AM
