is this a real turbonetics turbo?
Old Nov 21, 2007 | 08:21 PM
b17 turbo's Avatar
Default is this a real turbonetics turbo?
i bought this turbonetics turbo i was told it was a t3 i dont know alot about it i havent seen it on turbonetics web site here are some pics hopefullf someone knows what it is there is one number where the on the black housing where the turbo connects to the manifold that reads 0358 there is also a number on the silver part where the turbonetics badge is that reads 60 and on the side of the silver part it reads c 26 02
Modified by b17 turbo at 9:35 PM 11/21/2007
Modified by b17 turbo at 10:04 PM 11/21/2007
Old Nov 21, 2007 | 09:39 PM
Schister66's Avatar
Man U FTW
I would bet its a real Turbonetics unit. To find out more about it, take all the numbers you can find on the turbo and search them in Google. You'll find something eventually. If you dont have much luck that way, take the housings off and measure the inducer/exducer with a micrometer and report your results
Old Nov 22, 2007 | 10:49 PM
JDMeg95's Avatar
Default Re: (Schister66)
looks like a turbonetics housing so i bet its legit
Old Nov 23, 2007 | 12:47 AM
riceball777's Avatar
Default Re: is this a real turbonetics turbo? (b17 turbo)
yes that is a real turbonetics turbo. turbonetics turbos have that T stamped on the compressor and exhaust housing. what kind of turbo we dont know. the only real way to find out is to take the housind off and measure the wheel
Old Nov 23, 2007 | 05:46 AM
Clayton's Avatar
H-T Administrator
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I would bet its a real Turbonetics unit. To find out more about it, take all the numbers you can find on the turbo and search them in Google. You'll find something eventually. If you dont have much luck that way, take the housings off and measure the inducer/exducer with a micrometer and report your results</TD></TR></TABLE>
Holy crap Adam, that'd be a BIG micrometer. Do you mean a set of verniers?
Old Nov 23, 2007 | 04:50 PM
boostede46's Avatar
DANG IM IN THE SAME BOAT AS YOU HOPE YOU FIGURE IT OUT
Old Nov 23, 2007 | 05:50 PM
Newt Dog's Avatar
Default Re: (boostede46)
The (2)0358 is a stage 2 standard .63 a/r. T3/T4 50 trim if that helps.
Old Dec 2, 2007 | 11:53 PM
suprgato's Avatar
oh yeah its real it'll put down up to 500 hp no problem just put it on and boost 20psi!!
Old Dec 3, 2007 | 03:35 AM
turbodano's Avatar
Default Re: (suprgato)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suprgato &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah its real it'll put down up to 500 hp no problem just put it on and boost 20psi!!</TD></TR></TABLE>
More like 250-300hp
Old Dec 3, 2007 | 04:52 AM
SPOOLINmatt's Avatar
Default Re: (turbodano)
its def. an older one, i think all of them now are running the polished housings.
Old Dec 4, 2007 | 12:48 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">
More like 250-300hp</TD></TR></TABLE>
Hehe. The old stage IIs. I remember those. Those use to come on the F-MAX kits before turbonetics bought them out. They were rather peppy for straight LS motors that wanted a push. They were great on 11psi-13psi on an LS. Good to only about 350whp, Pushed..
Old Dec 4, 2007 | 02:53 PM
Joey.'s Avatar
* B A N N E D *
Default Re: (JDMeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMeg95 &raquo;</TD></TR><TR><TD CLASS="quote">looks like a turbonetics housing so i bet its legit</TD></TR></TABLE>
ProjectPTP
Feb 17, 2012 09:15 PM
asianboi313
Nov 13, 2007 03:59 PM
standbackimapro
Jul 31, 2006 09:53 AM
IntegraGSR(-1)
Nov 24, 2005 09:53 AM
whagkangmakulet
Nov 13, 2001 05:21 AM
