weird electrical problem... car won't start
Old Nov 21, 2007 | 04:04 PM
perseverance's Avatar
Default weird electrical problem... car won't start
ok...my friends car won't start. it's a 97 ek hatch.i checked the clutch relay, checked the ignition switch...still nothing. i ran power straight from the battery to the black/white wire on the starter and nothing. i unplugged the blk/wht from the starter and still no cranking. anyone have any ideas on this? i've never seen this problem before.
Old Nov 21, 2007 | 04:51 PM
Default Re: weird electrical problem... car won't start (perseverance)
anyone ever run into this prob before?
Old Nov 21, 2007 | 05:08 PM
Lmgrcivic's Avatar
start with the simple stuff have you checked your fuses and it wont crank at all or it wond turn over
Old Nov 21, 2007 | 05:35 PM
it won't crank at all...and yea i did check all the fuses. i'm a wizard with my DMM
Old Nov 21, 2007 | 05:52 PM
woolydotmatrix's Avatar
if you have jumped 12v power and good ground to your starter then you might need a starter
Old Nov 21, 2007 | 05:55 PM
Default Re: (perseverance)
check your ground straps to you trans from body , batt voltage and CCA, as well asyour ground from batt to body
nestea8869
10
Mar 26, 2022 10:12 AM
vplukas101
Jan 25, 2013 04:09 AM
jimboek
Apr 26, 2007 07:12 PM
whatcivic
Dec 6, 2005 05:20 PM
elpermgrande
Aug 9, 2002 06:43 AM
