quick question
Old Nov 21, 2007 | 03:51 PM
rexfiend1877's Avatar
Default quick question
is a jdm b16a engine and cable tranny a direct swap or do i need specific items besides mounts and the obvious
Old Nov 21, 2007 | 04:07 PM
VtecSyndrome's Avatar
Default Re: quick question (rexfiend1877)
search "B16 swap" in the archives of the EF forum to answer all your questions. with the proper mounts, axles and shift linkage a B16 will bolt into your 88-91 civic or crx, so mechanically it is a direct swap but you'll need to run some wires to make it work depending on what chassis it's going into (i.e. Si,Dx or std)
Old Nov 21, 2007 | 04:18 PM
Default Re: quick question (VtecSyndrome)
it will be going into a 1988 crx si
Old Nov 21, 2007 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexfiend1877 &raquo;</TD></TR><TR><TD CLASS="quote">it will be going into a 1988 crx si </TD></TR></TABLE>
If you rin OBD 0 our only need to run 3-4 wires,
1 wire for vtec solenoid
2 wires for vtec pressure switch
1 wire for knock sensor if applicable
if your running obd 1 you'll need a bit more wiring or you can buy the conversion from Rywire.
SEARCH SEARCH SEARCH!!!
good luck
Old Nov 21, 2007 | 06:35 PM
thanks man
Old Nov 21, 2007 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexfiend1877 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man</TD></TR></TABLE>
Old Nov 21, 2007 | 07:41 PM
draperj09's Avatar
SEARCH... and when you are done with that search some more. Good luck
aj96coupe
Feb 15, 2007 12:08 PM
94eh2
10
Nov 27, 2006 12:07 PM
CRX EF 88
Aug 30, 2005 11:53 PM
mr. Grind
16
Jun 16, 2004 04:20 PM
uNbrokeN
Feb 28, 2004 07:33 PM
