99 teg bumper on 94 teg... does it work?
Old Jun 24, 2002 | 11:21 PM
B-Series Sol's Avatar
Default 99 teg bumper on 94 teg... does it work?
I was thinking about buying an LS and rebuilding the engine entirely, so it would be pointless for me to buy a newer integra, so I decided to buy a 94.
However, I like the front bumper on the later style (97+ right?) and so I was thinking of just buying that bumper and putting it on my 94... is this possible? Are the headlights the same?
Also, do the bumper lenses switch over?
-Jake
Old Jun 24, 2002 | 11:23 PM
VTssblueEC's Avatar
New User
Default Re: 99 teg bumper on 94 teg... does it work? (B-Series Sol)
u'll need, 98+ headlights, bumpber cover, corner lens, and styrofoam absorber.
Old Jun 24, 2002 | 11:27 PM
Default Re: 99 teg bumper on 94 teg... does it work? (VTssblueEC)
are you sure the headlights are not the same?
Old Jun 24, 2002 | 11:55 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
they aren't.
Old Jun 25, 2002 | 03:38 AM
Vazquez911's Avatar
They are no way the same... the 98+ lights sit more at an angle, more so they are minutely larger. The changed the entire front and rear end after hitting 98+
Its not worth doing the switch, unless you're just wanting newer cosmetics... personally I like the 94-97 look, wasn't into the 98+ buldging duckbill look.
Old Jun 25, 2002 | 05:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 99 teg bumper on 94 teg... does it work? (Vazquez911)
I like the 98+ headlights way better, they always look cleaner and more crystal clear than 94-97 lights.
Old Jun 25, 2002 | 05:52 AM
IN VTEC's Avatar
You also need the bumper lense brackets if the bumper doesn't already come with them.
'94 to '97
'98 to '01 (w/ ITR front lip spoiler)
Old Jun 25, 2002 | 06:48 AM
project_DC2's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (IN VTEC)
98-01 are better. Cleaner and Sleeker...my opinion
Old Jun 25, 2002 | 07:39 AM
Doogie Howser's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (project_DC2)
98-01 with the itr lip is very nice, but i hate when people buy those foglights i think the ruin it
Old Jun 25, 2002 | 07:59 AM
B18Redline's Avatar
I like the 94-95 better IMO.
Old Jun 25, 2002 | 08:11 AM
Default Re: 99 teg bumper on 94 teg... does it work? (topfuel007)
i don't like the 94-97 because of the headlights and corners.. they look... dirty is the only word that comes to mind.. i dunno.
Old Jun 25, 2002 | 08:15 AM
Fooser's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (dLo GSR)
Ok 94 - 97 headlights are not slanted as much.
98 has more of a oval look to them. Reason is because people complained about snow getting stuck in the holes on the 94 - 97 integras.
So to answer your question.
You need new headlights, bumper lense brackets, bumper lenses, and bumper to do the conversion. The foam is just an option. It will help if you hit someone goiing like 5 mph any faster and theres no point.
Old Jun 25, 2002 | 08:54 AM
Vazquez911's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (PatrickGSR94)
LOL, you've never seen a refurbished 94-97 headlight have you? Or are ours THAT fogged out? I've seen people order from Honda 94-97 headlights, and they are JUST as clear.
The unclarity, is simply age... You will learn my young pupil... you will learn.
Old Jun 25, 2002 | 10:02 AM
Community Builder
My headlights aren't fogged, but the reflection on the chrome rings around the headlights don't look as sharp as they do on 98-01 lights
Hey I wonder if anyone has ever thought of painting those rings? If you take the headlight apart they attach to the clear lens w/ screws....
[Modified by PatrickGSR94, 1:03 PM 6/25/2002]
Old Jun 25, 2002 | 10:04 AM
Vazquez911's Avatar
Your car, just like mine is a 94... UNLESS you took your lights out, and baked them for five minutes at 350 degrees... thus allowing you to separate the seal. THEN professionally polishing both the exterior and the interior of the lens. THEN reassembling the ENTIRE THING, including re-sealing... Your lights are fogged... Period.
Vazquez - Who should've done this cleaning technique when he put his new front bumper on...
Old Jun 25, 2002 | 10:22 AM
migs's Avatar
Seems like this guy knows other peoples car more than the owners themselves.
Old Jun 25, 2002 | 10:54 AM
Default Re: 99 teg bumper on 94 teg... does it work? (advancexgsr)
advancexgsr did u do a 98-01 conversion to your 94 before the jdm front,and are those slipstreams or sw388 in that picture
Old Jun 25, 2002 | 11:20 AM
legendboy's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (mlambrecht)
My 94 after conversion
[Modified by legendboy, 1:21 PM 6/25/2002]
Old Jun 25, 2002 | 11:48 AM
Community Builder
My left headlight fogged and I took it apart and cleaned it out (that's how I know the chrome ring screws onto the clear cover). My right headlight has never been apart and it's not fogged, either. I have sanded and polished both headlights a couple of times.
Right headlight:
Old Jun 25, 2002 | 11:52 AM
Vazquez911's Avatar
Default Re: 99 teg bumper on 94 teg... does it work? (MiGs)
Seems like another newbie is trying to get a bad rep... when you see this car EVERY weekend... maybe I do know it... Want a hammer for yourself? Stupid nube
Old Jun 25, 2002 | 02:20 PM
IgniteTeg's Avatar
I say no doubt about it do the conversion much cleaner. You will need all those stuff mention above. Its a simple thing to do and the newer model just looks better
Old Jun 25, 2002 | 03:25 PM
migs's Avatar
Newbie? hahahah
[Modified by MiGs, 5:00 PM 6/25/2002]
7thgenRS
Jul 6, 2005 10:50 AM
Jeezer
Jun 27, 2005 11:46 PM
crxforum
May 26, 2003 09:25 PM
gtfourmn
Mar 10, 2002 11:17 AM
bhang
Jan 10, 2002 09:10 PM
