Injectors
Old Nov 21, 2007 | 03:35 PM
iv's Avatar
iv
Default Injectors
I need some help
Here is the situation I just swapped a GSR motor into a EG and none of the fuel injectors are working
They are OBD I injectors
This is what I have tried so far
2 sets of injectors
2 ECU's
New Fuel Filter
Newer Fuel pump
I have voltage at the injectors
I have continuity from the injector to the pin on the ecu for each injector
All grounds are good
I am stumped
Anybody have any ideas why they will not fire
Old Nov 21, 2007 | 04:05 PM
platinumx6's Avatar
Default Re: Injectors (iv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iv &raquo;</TD></TR><TR><TD CLASS="quote">I need some help
2 sets of injectors
2 ECU's
New Fuel Filter
Newer Fuel pump
I am stumped
Anybody have any ideas why they will not fire </TD></TR></TABLE>
are they in the right location?
Old Nov 21, 2007 | 05:11 PM
Colby71's Avatar
May sound stupid but do you have gas, and is there fuel presure.
Old Nov 21, 2007 | 05:14 PM
Lmgrcivic's Avatar
Default Re: Injectors (Colby71)
is the fuel pump coming on
Old Nov 22, 2007 | 03:42 PM
iv's Avatar
iv
they are in the right order
I have gas and fuel pressure at the rail
The fuel pump is coming on
Old Nov 23, 2007 | 04:50 AM
Colby71's Avatar
Default Re: (iv)
do you have gas going into the cylinders? Maybe it is not the injectors.
Old Nov 23, 2007 | 06:51 AM
iv's Avatar
iv
There is no gas coming out of the injectors I pulled the rail and tried to start the car no gas came out??
Old Nov 23, 2007 | 07:09 AM
Syndacate's Avatar
Default Re: (iv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iv &raquo;</TD></TR><TR><TD CLASS="quote">There is no gas coming out of the injectors I pulled the rail and tried to start the car no gas came out??</TD></TR></TABLE>
Then get a new fuel pressure gauge. You said it read fuel pressure at the rail, obviously if no fuel came out, there's no fuel pressure at the rail, get a new fuel pressure gauge.
Then see if you have fuel pressure.
Or maybe I'm understanding it wrong and there's fuel coming out of the rail if you remove the fuel pressure regulator - but nothing at the injectors, is that right?
If that's the case you don't have power going to the injectors, check the wiring from the harness. You said you tried two ECU's so I doubt that's the problem. Use a test light or multi-meter and make sure you're getting power at the injectors.
Blah, I just scrolled up and see you already checked that.
Hrm.
There's only one thing I can think of, and that's that you have power to each injector, just not enough power to open them up. Find out what it's supposed to be to open up an injector (12v at ?? amps?) and check that against what you have.
Weird problem.
Old Nov 23, 2007 | 10:41 AM
iv's Avatar
iv
Thanks anybody else have any ideas
Old Nov 23, 2007 | 12:58 PM
iv's Avatar
iv
Okay so I went and did some more checking of the voltage from the ECU and the injectors and the ECU is sending a ground when it is supposed to but the injectors are not firing
Could it be that maybe the fuel pump even new could be faulty and sending pressure but not sustaining it enough to start???
Old Nov 23, 2007 | 01:04 PM
bruised eg's Avatar
Default Re: (iv)
Check the connector at the left shock tower, the large 1 with the plug in it. If the plug is not there the injectors will not fire. Injectors are operated by ground, they always have power. Check all of your grounds again, especially the 1 at the thermostat housing.
Old Nov 23, 2007 | 01:27 PM
iv's Avatar
iv
Done the plug is there they all have power and the ecu does send the ground pulse when trying to start
Unhooked ground and therm housing sanded it and put it back on no luck
I'm ready to beat this car with a hammer
Old Nov 23, 2007 | 09:05 PM
Colby71's Avatar
Default Re: (iv)
Well I have an ax if you rather beat it with that.
Old Nov 24, 2007 | 12:38 PM
iv's Avatar
iv
I got it fixed today
It turns out i had 2 sets of bad injectors go figure
Old Nov 25, 2007 | 10:24 AM
Colby71's Avatar
wow that sucks but atlest they are fixed.
Old Nov 28, 2007 | 05:38 AM
bruised eg's Avatar
Default Re: (iv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iv &raquo;</TD></TR><TR><TD CLASS="quote">I got it fixed today
It turns out i had 2 sets of bad injectors go figure</TD></TR></TABLE>
Thats a freak deal, but at least its fixed.
Old Nov 28, 2007 | 10:45 AM
JDM94HATCH's Avatar
Default Re: (bruised eg)
bump
Dom_GsR
Jun 22, 2012 06:50 AM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
