cleaning valve train while head is still attached???
i recently pulled the valve cover off my b18c5 and its BLACK WITH SLUDGE, the entire valvetrain and head is black inside, is there somethin i can use to clean it out? any kind of solvent i can use? then drain the pan when im done? or is there anything i can run through the motor to clean it? it wipes off fairly easily.
its black because i had a PCV system problem and it made the motor pretty dirty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Seafoam. Use the search function to learn more.</TD></TR></TABLE>
i search all the time, but i had no idea seafoam will clean that out. ill give it a shot thanks
SVOboy
19
Jun 22, 2006 05:30 PM
Dammit_Dan_954
Dec 9, 2003 01:56 PM
