Suspension & Brakes Theory, alignment, spring rates....
bushing
Old Nov 21, 2007 | 11:10 AM
1993gsrcivic's Avatar
Default bushing
i got a 92 civic si hatch and i need new front lca bushing i was thinking energy suspension or is oem ok
what do you have oem or energy suspension
is there and negative affects from energy suspension
Old Nov 21, 2007 | 08:26 PM
Default Re: bushing (1993gsrcivic)
bump
anyone know whats better oem or es
Old Nov 21, 2007 | 08:31 PM
rawkus's Avatar
I don't have direct experience with the Energy Suspension bushing, but in general, the bushing will be stiffer which would create better "feel" due to less deflection. OEM will have less noise, vibration, and harness though. Your call on which you prefer more. If you change one side to the Energy Suspension bushing, make sure you change the other side.
Dan
Old Nov 22, 2007 | 08:05 PM
Default Re: bushing (rawkus)
anyone else
Old Nov 24, 2007 | 09:44 AM
PIC Performance's Avatar
Its been covered several times, and unless you feel like reading through the various threads on "pros and cons of polyurethane bushings", sifting through what you think is correct and incorrect information then analyzing that info on your own to determine what fits your needs, just go OEM.
prelude2.2
Nov 23, 2012 06:42 PM
CubbyChowder
Jul 10, 2011 08:16 PM
teambk8
May 2, 2009 08:02 AM
vti444
Jun 10, 2008 10:36 PM
EGO
Jun 25, 2003 10:55 PM
