98 V6 Accord Coupe Engine Problem
Old Nov 21, 2007 | 10:32 AM
stevenph4n's Avatar
Default 98 V6 Accord Coupe Engine Problem
My engine light just recently turned on. My car rumbles when I switch to Drive [auto] . Then when I start driving and step on the gas, my car accelerates late and then peels off. Any clue of what's going on? Please help. It is almost hitting 100K miles and the timing belt needs to be change. Can any of these be the problem?
Old Nov 21, 2007 | 12:25 PM
accord99power's Avatar
Default Re: 98 V6 Accord Coupe Engine Problem (stevenph4n)
check with a local tranny shop they are notrious for problems. letme guess your rpms goes high and you do not go anywhere and when it kicks into the gear it peals out? baby your tranny dude until you get it to the tranny shop. more then likely your vss sensor is throin your code.
Old Nov 21, 2007 | 12:57 PM
NokBlue's Avatar
Default Re: 98 V6 Accord Coupe Engine Problem (accord99power)
take it to autozone, they will read the CEL (check engine light) for free.
i agree with accord99power, sounds like your tranny.
Old Nov 21, 2007 | 01:03 PM
Default Re: 98 V6 Accord Coupe Engine Problem (NokBlue)
thats what i did when i had a similar prob on a 96 accord, they said it was the vss and the dude said yah it should fix the problem, this was when i wasnt on the brighter side of mechanics and bought the damn vss which of coarse didnt work, and they wouldnt take it back.
Old Nov 21, 2007 | 01:14 PM
stevenph4n's Avatar
Hrmm. How much did it cost you ?
Old Nov 21, 2007 | 01:15 PM
YeuEmMaiMai's Avatar
sounds like transmission problems and CEL could be EGR get it checked
Old Nov 21, 2007 | 03:46 PM
bought transmission at junk yard $400 and another $500 to install .
Old Nov 21, 2007 | 05:13 PM
DominicanYorkJL's Avatar
this same problem happens to my car..the rpms go up high then the car peels...after the car warms up it doesnt happen..but yea..is there any place i can get an auto transmission for cheap that actually works
F23Da
Oct 8, 2016 06:16 PM
ajezior
Jan 16, 2012 12:43 PM
SilverDc2
Nov 7, 2005 09:32 PM
hgiljr
Jun 23, 2005 06:13 PM
