tire pressure?
Old Nov 21, 2007 | 09:26 AM
benji7288's Avatar
Default tire pressure?
Anyone knows the correct tire perssure for Integra GSR Blades?
Old Nov 21, 2007 | 09:29 AM
.:Swig:.'s Avatar
Default Re: tire pressure? (benji7288)
On the tire it should state the min and max psi in the tire sidewall ..
Old Nov 21, 2007 | 09:31 AM
themikewoo's Avatar
Tire pressure raises 2-3 psi when it gets hot.
Old Nov 21, 2007 | 09:43 AM
fmrprojects's Avatar
Default Re: (themikewoo)
if you drive a passenger car and even if the tires are rated at 44psi max, you should still onl put in 33psi cause thats what the car recommends
Old Nov 21, 2007 | 11:26 AM
EK9Greg's Avatar
it also matters where you live too,colder weather or crappy Florida weather
Old Nov 21, 2007 | 01:21 PM
Perfectionist's Avatar
There should be a tire decal on the driver's side door jamb. That is the recomended pressure regardless of type of tire. The tire sidewall maximum pressure should never be used. (FWIW, I bump my pressure up 2 PSI above the label spec)
The PSI drops/raises with temperature decrease/increase. Don't remember for sure, but I think it's one degree PSI per ten degree temperature change. (Open for correction)
mugen92acintls
Mar 6, 2004 02:12 PM
SkRiBLaH
10
Feb 16, 2004 09:25 AM
Twigster311
Aug 10, 2003 05:31 PM
PoonHunter
Jul 14, 2003 11:39 AM
MooreBoost
Sep 5, 2002 03:26 PM
