Honda S2000 Honda S2000
Brand New Honda S2000 F22C1 S2000 Desigend Chaos Throttle Body Spacer!
Old Nov 21, 2007 | 09:16 AM
prelude1911's Avatar
Default Brand New Honda S2000 F22C1 S2000 Desigend Chaos Throttle Body Spacer!
Brand New Product! Designed Chaos Throttle Body Spacer!
We have develop a brand new spacer for the 2007 Honda S2000. The part is already installed on the car and we are waiting for dyno time at Church Automotive. We currently have it install on our 2002 Nissan Sentra SER 2.5L and it show an increase in 9 HP gain! Dyno sheet to prove it and Shawn @ Church Auto can also tell you it works! Our part has been featured in Nissan Sport Magazine.
-Increase in HP and Torque
-Increase Gas Mileage
-Taper Helix Design
Here are some pics of some of some spacers already made:
Nissan Sentra QR25DE Spacer
Nissan 350Z Spacer
Dodge Charger Spacer
Mitsubishi Evo Spacer
<FONT SIZE=""5"">2007 Honda S2000 Prototype Spacer</FONT>
Old Nov 21, 2007 | 09:20 AM
ap1lvr's Avatar
Default Re: Brand New Honda S2000 F22C1 S2000 Desigend Chaos Throttle Body Spacer! (prelude1911)
phenomenal
Old Nov 21, 2007 | 10:00 AM
papa5murf's Avatar
Looks nice, but how would this fare with a boosted application?
Old Nov 21, 2007 | 10:04 AM
Default Re: Brand New Honda S2000 F22C1 S2000 Desigend Chaos Throttle Body Spacer! (papa5murf)
We have a 1997 Turbo Honda Prelude that we also got a spacer made for. We will be doing that test also along with the S2000. Hopefully we can get it done next week. Both cars are running the spacer as we speak.
Old Nov 21, 2007 | 11:20 AM
ProjectDarkBlack's Avatar
so if a simple spacer makes so much power, why would it not be there from the factor?
Old Nov 21, 2007 | 11:23 AM
LAS2K's Avatar
that gain was with a Sentra. S2000 are already squeezed for power to begin with. I doubt any gains will be made...maybe 1hp, .5 tq.
rowdys2000's Avatar
it looks like a nicer TORNADO!!!!
sure am interested in seeing those dyno sheets
Old Nov 21, 2007 | 11:38 AM
silentdancer's Avatar
Default Re: (rowdys2000)
i need to see dyno sheets, before and after.
Old Nov 21, 2007 | 11:53 AM
high_revs's Avatar
Old Nov 21, 2007 | 12:44 PM
Default Re: (silentdancer)
Hopefully next week!
Old Nov 21, 2007 | 01:36 PM
dcturbols's Avatar
Default Re: (prelude1911)
Why do you already have it installed?
I hope you are planning to do a baserun first then show what your spacer can do, and not just base your gains on what people have reported getting before.
Old Nov 21, 2007 | 01:40 PM
Default Re: (dcturbols)
We install it to test fitment and make sure everything is okay. I will take it off before we head to the dyno and after we do a base run we will then reinstall the spacer to see if it makes a different on the S2K. On all the car we dyno with the spacer we do a base run first.
Old Nov 21, 2007 | 01:50 PM
dcturbols's Avatar
Sounds good, can't wait. The spacer looks like it has the same idea of 'The Tornado' with airflow, in terms of making the air spin, but looks more functional since there is no twirling fan.
You should make either a cold air or short ram with the same idea, making a larger area for the air to rotate and see if it makes more power.
Old Nov 21, 2007 | 01:59 PM
Our spacer will work with any aftermaket cold air or short ram intake as well as the OEM stock intake system.
Old Nov 21, 2007 | 02:03 PM
ap1lvr's Avatar
hey im from LB also. so sick.
Old Nov 21, 2007 | 03:09 PM
MidwestAutoWorks's Avatar
Default Re: (ap1lvr)
I doubt it will make HP on an s2000
Old Nov 21, 2007 | 04:05 PM
CDN Yellow ITR's Avatar
what does a Throttle Body Spacer do???
Old Nov 21, 2007 | 04:45 PM
Default Re: (CDN Yellow ITR)
The spacer is a US patented helical bore design often used on aircraft. Its purpose was intended to increase air pressure, resulting in more power and torque. The charge of air is taper through like the nozzle of a water hose(creating pressure). Then forces the air to turn and spooled without having to lose momentum, as it makes its way through the intake manifold. Spacing between the intake manifold and throttle body also increasing plenum length. Throttle response is a lot more crisp. Email me for more info. @ Sales@ForumRacing.com
2mchbst
Jan 4, 2010 03:31 PM
cmdr430
Honda S2000
64
Sep 6, 2007 04:34 AM
TurboDANDEE
Honda S2000
Jul 3, 2003 09:36 PM
xunkn0vvnx
Honda S2000
Dec 21, 2002 12:53 PM
