omni power test pipe question
happy thanksgiving guys!
i have a couple of days off and i was going to install my omnipower test pipe today. i have everything i need. however, the more i thought about it, the more i wondered:
do the slipjoints on the adjustable test pipe need welding? im sure it wouldnt hurt to have this done, i just dont really know anyone that can weld. and my local muffler shop is pretty schwaz.
thanks.
thanks.
Yes, they will need welding.
You'll need to tack weld them in place while you get the fit just right, than fully weld them shut.
This is why majority of "no tools required, no welding" exhaust kits are bullshit.
Nice piece
Nice piece
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by get RIGHT »</TD></TR><TR><TD CLASS="quote">From my experience. The 02 bung didnt line up in the same place as OEM either.</TD></TR></TABLE>
it does not line up, the O2 on the stock cat is in the back, the OMNI is in the front.
i hope its going to be a simple matter of extending wires.
how about exhaust clamps, ghetto, but might work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR#0427 »</TD></TR><TR><TD CLASS="quote">
i hope its going to be a simple matter of extending wires. </TD></TR></TABLE> i have the same problem and no extending the wries didnt work not enough room for the o2 sensor it fits but rubs and over time will fail . ugh check engine light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsr001 »</TD></TR><TR><TD CLASS="quote"> i have the same problem and no extending the wries didnt work not enough room for the o2 sensor it fits but rubs and over time will fail . ugh check engine light
what if you rotated the flange 180 degrees, and held the wires out with something? clearance issues im sure, but ill try and see.
</TD></TR></TABLE>what if you rotated the flange 180 degrees, and held the wires out with something? clearance issues im sure, but ill try and see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL »</TD></TR><TR><TD CLASS="quote">I need to get mine welded... It leaks like hell, every time I let off the gas, it backfires out of the openings.</TD></TR></TABLE>
That don't sound too good. It turned out after I realized about the bung, I never even bolted mine up and found a SMSP cat instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* »</TD></TR><TR><TD CLASS="quote">i don't have mine welded and I have zero issues. I'm also NOT running a 2nd O2 sensor.</TD></TR></TABLE>
are you throwing a code with that? cause that would sure make things easy.
Just think of it like this: When you connect two pieces of speaker wire together and twist the ends, a connection is made, and it will continue the current from one wire to the other. However, if you twist those same wires, and then solder them together, the connection will be more concrete, more durable, and will last longer.
To think that if you leave the slip joints as is, and not weld the joints together, that you would have a sealed exhaust, is just incorrect. The entire exhaust track moves and flexes while you drive. Those slip joints will also move and under extreme exhaust pressure in the pipes, air will find its way out of those joints.
Welding is very cheap. No point on cutting corners on something so minuscule. Just go get the thing welded.
I bought one over a year ago, and haven't put it on for this very reason. The dollar is doing so crappy against the Euro it would cost me more to get it welded than I paid for the test pipe.
</TD></TR></TABLE> you mean have the o2 sensor hanging down wards?? i would rather not run the sensor and just live with the code...tried as well hangs way to low not a good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam »</TD></TR><TR><TD CLASS="quote">i have this test pipe.. not welded, works mint</TD></TR></TABLE>
You may think it does, but it doesn't. It can work better. Weld it shut. Seal the friggin exhaust track. Running this test pipe without the slip joints welded is like having an exhaust leak. You loose pressure and disturb the flow of air through the piping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam »</TD></TR><TR><TD CLASS="quote">okk might do it anyway
i never knew just thought thats how they are..
It's all good bro. Exhaust kits and test pipes like this have slip joints for the sole purpose of being able to custom fit the length, but they should always be welded shut.
</TD></TR></TABLE>It's all good bro. Exhaust kits and test pipes like this have slip joints for the sole purpose of being able to custom fit the length, but they should always be welded shut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_gs-r »</TD></TR><TR><TD CLASS="quote">Mine isnt welded and i have had no issues. It has been on my car for over a year. No exhaust leaks or anything.</TD></TR></TABLE>
same here, the actually held together by a really tight fitting BC spec II exhaust
