random click start no start
Are you sure its the same battery number wise and everything?
How about your grounds are they all secure for the trans and motor?
Battery ground loose?
Battery Terminals loose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by De_tour »</TD></TR><TR><TD CLASS="quote">
Everything is hooked up and battery is the right one. It seems to happen when my car sits for a longer period of time because my volt meter reads at about 13 after driving and then in the morning its around 12. </TD></TR></TABLE>when it clicks do all the dash lights turn off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by De_tour »</TD></TR><TR><TD CLASS="quote">I dont know, it hasnt happend again since, but my volt meter is showing that that alternator is pushing out a constant 15v even with no load of any accessories at idle. So now after a trip, the battery reads 14v when i shut the car off
</TD></TR></TABLE> sounds like a bad ground. get some brake cleaner next time and spray all the battery terminals and all ground terminals
Check the 2 grounds going to the motor. One on the tranny and one on the Power steering or top of head.
Also can u hear the PGI realy on the left side of the mid dash click ?
if it is clicking and not cranking, hit it with a hammer.
i am serious, and dont call me shirley.
no i am not kidding. sometimes the brushes get stuck and they need to be motivated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">if it is clicking and not cranking, hit it with a hammer.
no i am not kidding. sometimes the brushes get stuck and they need to be motivated.</TD></TR></TABLE>lol. im not sure if hammering the starter solenoid is going to be a long term solution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">check for voltage drop from battery to stater. check ground for continuity, if thats ok, replace your stater.</TD></TR></TABLE>
go with what he said... if not most hondas have been known to have that wire that goes to the nutral safety switch to die.. (Mine did) i just cut it and ran a seperate one to the ignition and to the S terminal on the starter... started right up...
oh yeah EDIT that means you dont need to step on the clutch to start the car...
true that works sometimes also... just quick fast diags on ur cars
]Hmm really wierd the dact that your alternator is putting out that much might have over charged the battery which killed it and now its not able to hold a charge?
Im not exactly sure what the normal output of our alternators are supposed to be though....
