K24/K20A3 Swap questions...
Old Nov 20, 2007 | 11:05 PM
square_1's Avatar
Default K24/K20A3 Swap questions...
So from what I understand (from searching) you CAN put a K20A3 head onto the K24 block...? Or is that incorrect?
If it is true what are the power gains people are getting from that? I assume more torque? What about HP? At what RPMs?
On hmotorsonline they have the K24 long block for like 850 bucks. That sure beats that price of a turbo for now, etc and if it has a decent amount more power than my EP3 it seems like a good idea.
I assume all of my EP3's bolt ons will still work too, since they bolt to the head and not the block.
But mainly I am just curious to see what the power output numbers are looking like, and how high it REVs and the compression ratio and whatnot.
THanks guys.
Old Nov 20, 2007 | 11:12 PM
risktypeS's Avatar
Default Re: K24/K20A3 Swap questions... (square_1)
i think you read incorrect.
k20a2 head onto a k24a1 (crv) block. redline decreases to 8 grand. now a 2.4L with more torque. HP goes up maybe 10-15 (more depending what mods you have done to it) hp but you have an excellent torque increase. Instead of 139lb (varying) you get like 160-175 varying. k20a3's are worthless unless you fully build them or boost.
the k20a3 vtec-e (vtec-efficiency) for fuel economy is what kills ya since you don't have the vtec the k20a2 utilizes.
Old Nov 21, 2007 | 12:25 AM
bmoua's Avatar
Default Re: K24/K20A3 Swap questions... (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">i think you read incorrect.
the k20a3 vtec-e (vtec-efficiency) for fuel economy is what kills ya since you don't have the vtec the k20a2 utilizes.</TD></TR></TABLE>
never knew the k20a3 was vtec-e...good info
Old Nov 21, 2007 | 08:12 AM
square_1's Avatar
Default Re: K24/K20A3 Swap questions... (bmoua)
So A3 won't go on there? Dang!
What about just putting a straight K24 in there... Any good benefits of that?
Old Nov 21, 2007 | 09:14 AM
risktypeS's Avatar
as in swapping for k24a2(tsx)? nothing wrong with that.
you can put a k20a, k20a2 or k24a2 and you'd be satisfied for N/A.
Old Nov 21, 2007 | 06:04 PM
square_1's Avatar
Ok. So what are the power stats on just a stock K24 engine. Would it be nicer to go with then my A3 or should I just boost my A3 and be done with it?
Old Nov 21, 2007 | 07:35 PM
risktypeS's Avatar
what are your goals.. what do you want?
Old Nov 21, 2007 | 09:28 PM
square_1's Avatar
High 13s to low 14s on a very streetable commuter that still gets decent gas milage and has full interior (no race stuff)...
Old Nov 22, 2007 | 07:24 AM
risktypeS's Avatar
all motor or boost?
Old Nov 22, 2007 | 08:59 AM
square_1's Avatar
Well I am not sure. I am thinking boost. I have read so far that the K20A3 handles boost pretty well. That could be an option and I am sure a less expensive one than going NA too.
Old Nov 22, 2007 | 10:41 AM
risktypeS's Avatar
then turbo it is. You could make easily 300hp stock, run 12's with a turbo kit w/o any major mods and be streetable. just get a rightfully sized turbo for your car. the turbo kits i have seen like greddy, hks etc... they are all small turbo's. just remember if you are going turbo you need to upgrade your fuel pump to a 255.
Old Dec 21, 2007 | 07:31 PM
cbmprelude's Avatar
* B A N N E D *
is a k20a3 really vtec-e? Has anyone swapped a k24 into an ep3?
Old Dec 21, 2007 | 08:31 PM
risktypeS's Avatar
Default Re: K24/K20A3 Swap questions... (cbmprelude)
yes to both questions
Old Dec 21, 2007 | 08:41 PM
dc5RickK20's Avatar
if all you looking for is 13s i would just put a jackson racing supercharger on the a3 or if you wanna swap i would swap in a k20a2 with some light cams and some nice bolt ons. i ran 13.6 in my rsx with just bolt ons but i think i might just go boost in my rsx just to shut up some EVO guys i know
Old Dec 21, 2007 | 08:43 PM
square_1's Avatar
Default Re: K24/K20A3 Swap questions... (dc5RickK20)
13.6 with bolt ons? That is like a second quicker than stock. Damn.
Well I am thinking LIGHT boost and LIGHT turbo. Something to spool quickly to like 6 to 8 pounds.
We'll see what happens, new tires and suspension are ready to be installed as of right now. That will make a noticable difference.
Old Dec 24, 2007 | 06:47 AM
1986's Avatar
check this thread out
k20/k24 build
http://forums.clubrsx.com/showthread.php?t=392509
Miracle11
May 28, 2010 11:46 AM
jdmdc5integra
Jul 2, 2007 12:43 PM
03EM2guy
Nov 4, 2006 02:46 PM
bigwill_2004
17
Sep 27, 2006 07:20 PM
axistang
Apr 27, 2004 06:10 PM
