Need an Answer.....Can I get these Wheels to fit my EM1?
Old Nov 20, 2007 | 08:30 PM
asianbluesi's Avatar
Default Need an Answer.....Can I get these Wheels to fit my EM1?
I found a set of 17x7 wheels that I really want to put on my EM1. But the problem is the offset of the wheel.
Its a +20 offset with a 205-40-17 tire.
Will I have extreme rubbing issues?
Can I make it work, or is there no point?
Also, what if the wheels were a +25 offset instead?...would it still have rubbing issues?
Thanks!
Old Nov 21, 2007 | 04:04 AM
toyomatt84's Avatar
Sanji
Both offsets will rub, unless you're running extreme camber.
Old Nov 21, 2007 | 04:21 AM
SpeedStar Racing's Avatar
Default Re: (toyomatt84)
if you roll you fenders then it should work but may also need the perfect ride height as well so coilovers would be good also and neg. camber as matt just mentioned
Old Nov 21, 2007 | 07:18 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (SpeedStarRacing)
205/40-17 will give you the same ride height as your stock tire size.
KashMillien
Aug 19, 2015 07:12 PM
WannaRun??
Jul 14, 2012 08:20 PM
MadCivic1999R
Nov 12, 2011 06:06 AM
dannythewonder
Honda S2000
Sep 20, 2010 11:19 AM
grey_ghost
Jan 21, 2008 08:57 AM
