Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CRV Brakes
Old Nov 20, 2007 | 06:55 PM
bwest05dm's Avatar
Default CRV Brakes
I plan on doing a brake job for my sister on her 2000 cr-v. I was just wondering if i needed any special tools or tricks. plus, her brake light periodically comes on, i am assuming it is a wear sensor? thanks for your help.
Old Nov 20, 2007 | 10:43 PM
bittles110's Avatar
Default Re: CRV Brakes (bwest05dm)
The brake light is coming on because of the decreased level of brake fluid in the master cylinder due to worn pads, there is not a pad wear sensor.
Off the top of my head, you don't need any special tools, but here is a list that might help.
The usual wrenches or sockets, 10, 12, 14, 17 mm. You will need a 17mm open end wrench for the slider pins. Be sure to grease them. A large pair of slip joint pliers for pushing the piston in will help, or get the piston compressor tool from a autoparts store. If you are taking the rotors off, an impact screwdriver is *highly* recommended.
Other than that, brakes are pretty straightforward. Keep things clean, and make sure your bolts are tight.
Novacoma
Honda CR-V & Element
Jun 28, 2017 01:35 PM
ksweetland
Suspension & Brakes
12
May 18, 2012 03:19 AM
Civic_07
Suspension & Brakes
May 5, 2008 09:31 PM
erikgsr
Aug 23, 2005 10:05 AM
miataguy
Jan 26, 2003 11:25 AM
