JDM DC2 Headlight Question....taking HID from HID light n swapping to non HID light..?HELP ALL
Old Nov 20, 2007 | 06:51 PM
brainzTEG's Avatar
Default JDM DC2 Headlight Question....taking HID from HID light n swapping to non HID light..?HELP ALL
OK GUYS HERE IT GO IM NEW TO ALL OF THIS MY CAR COUGHT ON FIRE N ONE OF MY HEADLIGHTS BURN OUT THEY STILL LIGHT UP BUT JUST MESSED UP LIKE ALL BLK AND ****..THEY WHERE 98 SPEC JDM ITR HID HEADLIGHTS ...I JUST BOUGHT A SET OF NON HID JDM ITR HEADLIGHTS...MY QUESTIONS TO YOU GUYS NOW IS CAN I BAKE OPEN BOTH SET OF HEADLIGHTS N SWAP OVER THE HID SETUP N PUT IT INTO THE NON HID SETUP ... I RATHER THIS THAN AFTERMARKET HID BECAUSE I LOVE THE CUT OFF LINE ON THE OEM JDM ITR HID HEADLIGHT ... N I WANNA SWAP THE WHOLE SETUP TO A SET OF NON HID HEADLAMPS IS THIS POSSIBLE IF SO HOW..... PLEASE THANKS FOR THE HELP VERY THANKFUL
Old Nov 20, 2007 | 07:43 PM
m R g S r's Avatar
Default Re: JDM DC2 Headlight Question....taking HID from HID light n swapping to non HID light..?HELP ALL (
the brackets holding the projector and the projector itself should be metal, so they shouldn't have melted in the fire. so yes, open both of em up and swap all the necessary parts over. I'm not sure how the balasts mount to the ITR headlights, but i think i remember seeing them on the backside of the projector, so it shouldn't be a problem mounting them. If I'm wrong, then you prob need to find a way to mount the ballasts because the non HID headlight housings probably dont have a place to mount them.
Good luck. swap should be pretty self explanatory.
Old Nov 21, 2007 | 09:00 AM
brainzTEG's Avatar
thanks for the info im tryin to do this asap anyone else with info ?
heres pic
Old Nov 21, 2007 | 09:01 AM
brainzTEG's Avatar
do i have to change the projector lens n **** ?
Old Nov 21, 2007 | 09:09 AM
beepy's Avatar
Instead of swapping all of the guts over, why don't you swap only the damaged parts, ie put the new lenses on the HID housings?
Old Nov 21, 2007 | 09:32 AM
viet_boi_racin's Avatar
you can try pulling the plastic lense off and see if the internals will transfer and mount into the new housings.
Otherwise, you can can take the projectors out of the burnt headlight, and retrofit it into the non HID headlights. This will require you to cut the projectors out of the old headlights. Cause If I remember correctly, the JDM integra headlights has the projectors and the bracket are one piece.
Or you can pick up some TSX projectors, and do a retrofit in your non HID headlights, and use your existing ballast, ignitor and bulb. and have a better cut off then the JDM hid projectors.
ballinthavx
Feb 25, 2010 11:28 AM
JSPECHB
Dec 28, 2004 06:06 PM
rough_draft
Jun 4, 2004 03:20 AM
