Brain Dead
Old Nov 20, 2007 | 05:14 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Brain Dead
Im confused on the whole CRX dash being in a Civic and what wiring harness to use.
I have a 91 Si and used my harness for my B16A and works fine, but im eventually throwing my motor in my new shell which has a crx dash in it.
Should everything be fine - harness and motor with dash wise ?
Modified by x4thGenCafe at 6:46 PM 11/20/2007
Old Nov 20, 2007 | 05:47 PM
OF THE KINGS
Default Re: Brain Dead (x4thGenCafe)
noone ?
Old Nov 20, 2007 | 06:15 PM
VtecSyndrome's Avatar
your dash wiring should not be affected by the motor if installed right, as long as the crx dash is wired up correctly (should be plug-n-play I think) then you good there no matter what motor you run. the ECU is the only place in the cabin that needs to be modified normally.
Old Nov 21, 2007 | 06:14 PM
OF THE KINGS
Default Re: Brain Dead (VtecSyndrome)
thanks d00d
i figured that out at work today I was just being stubborn and dumb last night so i figured i would post up
benn2k
12
Feb 19, 2011 03:10 PM
KDvtec5757
Jul 2, 2009 03:47 AM
PrettyMicky951
Jun 11, 2008 06:15 PM
x4thGenCafe
Nov 20, 2007 08:18 PM
b16_ef
Mid-Atlantic (Sales)
Aug 21, 2006 06:59 PM
