Sudden shift lock & transmission problems
Old Nov 20, 2007 | 05:08 PM
idewson's Avatar
Default Sudden shift lock & transmission problems
Hey guys. I have a 91 lx auto. When I went to go to work this morning I could not get the shifter out of park. The only way I could get it to shift into drive was to engage the key interlock. Reverse worked fine, it went right into drive but then didn't want to shift into 2nd gear unless I rev'd over 4k and released the accelerator very quickly. Shifting to 3rd is even worse. It wont shift into 3rd unless i get close to 5k and let off real quick. Most of the time I can't even get it to go into 3rd. Are these problems related?? I have had no problems with either the shift lock or the transmission up to this point it just was all screwed up this morning out of nowhere.
The atf looks good, the throttle control cable looks to be working properly, any ideas?
Old Nov 20, 2007 | 07:52 PM
IMALLSLO's Avatar
Default Re: Sudden shift lock & transmission problems (idewson)
I cant see the two being related. To check the interlock check your brake lights. The same circuits operates both. If your brake lights are out a bad brake switch will cause a bad interlock. As far as the shifting,couldnt say at this point.
Old Nov 21, 2007 | 02:41 PM
idewson's Avatar
Default Re: Sudden shift lock & transmission problems (IMALLSLO)
Thanks. Does anybody else have any ideas about the transimission problems. I have no check engine light or anything and like I said no previous signs of any problems. Anything I should do b4 I take it somewhere to get looked at?
Old Nov 21, 2007 | 02:53 PM
kreush33's Avatar
Check to make sure you have trans fluid and it is full. could just be the speed sensor that tells the transmission when to shift
Old Nov 21, 2007 | 03:35 PM
idewson's Avatar
Default Re: Sudden shift lock & transmission problems (kreush33)
yeah i checked the fluid and its full. good suggestion with the speed sensor. sounds like that could be the problem because it downshifts sooner than usual too. I'll check that out.
Old Nov 21, 2007 | 04:18 PM
idewson's Avatar
ok the rear window brake light is not working but the regular tail lights are. is the malfunctioning window light the problem for the shift lock? now if it is, i need to check the shift lock solenoid correct?
Old Nov 22, 2007 | 04:05 AM
Chiovnidca's Avatar
So your brake lights dont work huh? Try the horn, if it's dead inspect your fuses. If the horn works check the brake switch.
Old Nov 22, 2007 | 08:52 AM
IMALLSLO's Avatar
3rd brake light has nothing to do with the interlock. Its probally just a bad bulb. Its turkey day but when I get some time ill investigate the curcuit to indentify fuses,grounds etc. and get back to you.
Old Nov 22, 2007 | 09:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMALLSLO &raquo;</TD></TR><TR><TD CLASS="quote">3rd brake light has nothing to do with the interlock.</TD></TR></TABLE>
No, but the brake switch does. Which is by far the most common problem I see with the interlock systems.
Old Nov 22, 2007 | 09:53 AM
IMALLSLO's Avatar
Default Re: Sudden shift lock & transmission problems (Chiovnidca)
Tailights are working which usually rules out brake switch.
Old Nov 22, 2007 | 11:37 AM
Chiovnidca's Avatar
Tailights are working which usually rules out brake switch.</TD></TR></TABLE>
jonkissane
Honda Civic (2006 - 2015)
Sep 8, 2025 10:40 AM
kimohands
Apr 20, 2019 06:26 PM
templarvisonz
Transmission & Drivetrain
Apr 28, 2009 10:55 AM
Bitpicker1011
Aug 26, 2004 10:15 AM
