In need of help spark problem is driven me nuts
Old Nov 20, 2007 | 04:39 PM
hondaboy_1.8's Avatar
Default In need of help spark problem is driven me nuts
Well guys i got my zc in my 1989 honda civic. At first i had a little spark then went away so i looked at my computor and it was show the tdc code so i switched the white and blue wire with the orange and blue now i have no codes showing and still no spark. Can anyone give me some ideas i would really apricate it
Old Nov 21, 2007 | 04:14 AM
Default Re: In need of help spark problem is driven me nuts (hondaboy_1.8)
Can anyone plz help me
Old Nov 21, 2007 | 05:38 AM
90efhatch's Avatar
I will look at my car at lunch time and get a pic for you for the wiring.
Old Nov 21, 2007 | 07:00 AM
Default Re: (90efhatch)
k thanks just the on codes thing is driven really bothering me and i have power to the distrubutor just no spark but that pic will hopefully help me
Old Nov 21, 2007 | 09:26 AM
90efhatch's Avatar
Default Re: (hondaboy_1.8)
the pic kinda sucks its from my phone. but the little prong is on the top and from the back of the plug where the wires go in the orange wires are on the right and then the white wires and then the single white wire by itself.
the main thing is to not get the 2 white wires confused. if you have then you can strip the wire loom back and see that the white wires and orange wires are twisted and sheilded together. the single wire will be by itself with the other wires for the cam sensor.
You cant see it in the pic but I think the wires with the blue stripe go on the top.
You can also look at the other end of the plug that goes into the distributor it has the colors (at least mine does) on that plug.
If that does not fix it then you might have a bad coil or igniter. I hope this helps.
Old Nov 22, 2007 | 05:15 AM
Well it helped me with the one wire i had wrong but still no spark i put a new ignitor in that my buddy had i tested all my wires and they are working iam getting my fuel injectors power. So i just ordered a brand new distrubutor 250 bucks later hoppen thats wut is wrong i with it
the1337aaron
14
Oct 12, 2010 06:16 AM
ah_leckz
Jan 17, 2010 10:32 PM
1503ef9
Dec 21, 2008 10:50 AM
PrestonCRX
Apr 7, 2006 06:30 PM
BoRiCuA
18
Jun 21, 2004 12:15 PM
