Suspension & Brakes Theory, alignment, spring rates....
blox rear lower control arms
Old Nov 20, 2007 | 04:21 PM
1993gsrcivic's Avatar
Default blox rear lower control arms
my lca bushing where my strut mounts are broke i wanted to know where i can get new bushing or
do i have to get new arms
will oem fit?
is this like a defect?
Old Nov 20, 2007 | 06:01 PM
Targa250R's Avatar
be professional
Default Re: blox rear lower control arms (1993gsrcivic)
Assuming a 1993 Civic, that bushing costs less than $20 at any Honda dealership parts department.
Old Nov 21, 2007 | 09:06 AM
.:Swig:.'s Avatar
are you talking about getting blox lca's to replace your oem? or replacing the bushing in the blox lca?
Old Nov 21, 2007 | 10:35 AM
Default Re: blox rear lower control arms (.:Swig:.)
i wanna replace the bushing in the blox lca, its shot
Old Nov 21, 2007 | 02:52 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">i wanna replace the bushing in the blox lca, its shot</TD></TR></TABLE>
Oh. I misunderstood.
In that case, you probably have to get new arms. I've no idea if a stock bushing will fit.
It's been well documented that the bushings in Blox control arms are garbage.
Old Nov 21, 2007 | 09:30 PM
.:Swig:.'s Avatar
do they have a warranty?
Old Nov 22, 2007 | 05:41 AM
they was on the car when i bought the car
Old Nov 22, 2007 | 12:49 PM
crexer's Avatar
go back with oem lca's they are probably about 70 bucks brand new each with all bushings in them and should last you another 10 years. Blox is document junk as already said. http://www.hondaautomotiveparts.com
Old Nov 22, 2007 | 02:58 PM
Default Re: blox rear lower control arms (crexer)
is there other better ones like skunk2 or omni, i didnt want to go back to stock
Old Nov 22, 2007 | 03:07 PM
crexer's Avatar
go with the omni's newest version if you just HAVE to have an aftermarket lca
Old Nov 22, 2007 | 03:17 PM
or will energy suspenion bushing fit inside as a replacement
Old Nov 22, 2007 | 03:35 PM
crexer's Avatar
why dont you try contacting blox, im sure they have had this issue arise a few thousdand times after selling crapply lcas
Old Nov 22, 2007 | 07:59 PM
gabebauman's Avatar
I would just look for some used oem lca's...I bet you could get a used set for under $30 shipped here on honda-tech.
Old Nov 23, 2007 | 07:59 PM
blackeg's Avatar
Default Re: blox rear lower control arms (gabebauman)
so how long did the blox bushing last?
Old Nov 23, 2007 | 08:58 PM
Default Re: blox rear lower control arms (blackeg)
i had the car 4 like 2-3 months and they was on there when i bought them
Old Nov 24, 2007 | 06:28 PM
LoneAutosport's Avatar
Go with some OEM arms, aftermarket arms are just for bling in my opinion..
Old Nov 25, 2007 | 09:15 AM
blackeg's Avatar
Default Re: blox rear lower control arms (LoneAutosport)
oem arms are 2x or more expensive, however, oem is almost always better quality
Old Nov 25, 2007 | 10:41 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">oem arms are 2x or more expensive</TD></TR></TABLE>
What?
Both rear lower control arms - new from any Honda dealership, equipped with sway bar mounting holes, and pre-loaded with bushings that will last at least 8 years and possibly more - would run him a grand total of $179.42 + tax.
A pair of Blox rear lower control arms, with bushings that are doubtful to last much longer than a year, is $129.95 + shipping.
That's a difference of $49.47 before tax or shipping - meaning that the stronger, longer-lasting OEM arms only cost 38% more, not 100%. OEM arms are also the correct length unlike the Blox arms, so they don't screw up the suspension geometry and track.
The best part about OEM control arms? You can buy the bushings separately.
Old Nov 25, 2007 | 02:50 PM
DrewMD's Avatar
Davis Photography
Are they really this bad? Have they updated any of their designs on the bushings recently?
Old Nov 25, 2007 | 06:30 PM
blackeg's Avatar
Default Re: blox rear lower control arms (Targa250R)
i was at my local dealer looking at ek rear lca's. 220 bucks a piece i think he said. it was over 200 i know that. i got blox's for 130 shipped
Old Nov 26, 2007 | 03:15 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">i was at my local dealer looking at ek rear lca's. 220 bucks a piece i think he said. it was over 200 i know that. i got blox's for 130 shipped</TD></TR></TABLE>
New OEM rear lower control arms for a '96-00 Civic are $162.82 + tax for the pair . . .
Are you sure he wasn't looking at the trailing arm? Those are $240.67 apiece.
Old Nov 26, 2007 | 06:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
haha I find it humorous how some of these aftermarket parts are claimed to be so awesome and so much better than stock, when in reality they're junk compared to stock.
I still have the same rubber bushings in my LCA's that were put in there in Japan 13+ years ago. Granted they're dry rotted a bit, but they're not nearly as bad as some of these polyurethane bushings I've seen after only 2 years.
I know my original rubber shifter bushings that I took out 5 years ago (8 years old at the time) were not NEARLY as bad as the polyurethane replacements I took out recently after only 5 years of use. I replaced them with new OEM rubber pieces.
Old Nov 26, 2007 | 07:38 AM
gabebauman's Avatar
I'm sure there are tons of knuckleheads here on H-T that have switched to the blingy rear lca's and would be more than willing to sell you their used oem lca's for less than $50. Just make a WTB thread and I'm sure you'll get all kinds of hits.
Old Apr 23, 2008 | 11:04 PM
acmoc's Avatar
actually, yeah. Kingmotorsports has some from this one brand that fit.
Old Apr 27, 2008 | 03:12 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">so how long did the blox bushing last?</TD></TR></TABLE>
3 months and they cracked on me, contacted blox 2 times, no responce...
