Can i use OBD2a Injectors with a P28?
Old Nov 20, 2007 | 03:05 PM
user 98292739's Avatar
Default Can i use OBD2a Injectors with a P28?
I just swapped in my Y8 in place of my Y7 i had to use my Y7 injectors as i had 780cc injectors in the y8 and i wanted to run a stock map.
The Y7 injectors were working fine before i pulled them out. I stuck them in the y8 and now i am getting a code 16 Fuel Injectors.
i am running a obd 1 conversion with a p28 w/ y8 map.
I called my friend he said he had the same problem he just threw in obd1 injectors and teh code was gone.
so can i run obd2 injectors with an obd1 ECU?
i am also throwing a Code 36 traction control!!! but i think thats casue teh map i got was well jdm...
Old Nov 20, 2007 | 03:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: Can i use OBD2a Injectors with a P28? (The Lobster)
Yes, there should not be any issue running OBD2 injectors off of a P28. Is your conversion harness and wiring all correct? Is the ECU known to be in working order?
Old Nov 20, 2007 | 03:48 PM
ya ECU is def workign order i pulled it working out of my crx.
I didnt have to wire anything for my injectors so that couldnt be it.
Conversion Harness seems correct i dont have any other CELs other then traction control.
blah i wonder what could be calling it to be faulty.
johnjw
Apr 30, 2012 02:00 AM
big-cat
Nov 3, 2006 07:17 PM
Ax3l
Oct 21, 2005 01:33 AM
dan89crxsi
Mar 25, 2005 09:50 AM
EJ2-Fluffy
11
Jan 13, 2005 03:01 PM
