ls vtec compression ratio?
Old Nov 20, 2007 | 02:12 PM
the_big_dl86's Avatar
Default ls vtec compression ratio?
does anyone know the compression ratios for an ls vtec with a b16a2 head with gsr pistons and with p30 pistons?how much of a difference in power will they make vs each other?SOMEONE HELP!
Modified by the_big_dl86 at 6:18 PM 11/20/2007
Old Nov 20, 2007 | 09:15 PM
iluvmyef9's Avatar
Default Re: ls vtec compression ratio? (the_big_dl86)
really if your going to use gsr pistons i would just do a poor mans type r in a gsr block but if you have both block laying around i would take everything out of the LS block and put it in the gsr block stright sleeper just tell everyone its a poor man type r and its a better build for a ls vtec like that because their is no oil line no rep tapping the head i am doing a build with the same set up in a gsr block but with a eagle crank scat rod and je 12.5... till i sace more money to have my b20/vtec resleeved
Old Nov 21, 2007 | 08:58 PM
killerpenguin21's Avatar
Default Re: ls vtec compression ratio? (iluvmyef9)
or you could just do what i did and get the black braided stainless line, and black fittings so you cant even see the oil line from head to block, and it takes like 5 minutes to plug the hole in the head.
Old Nov 21, 2007 | 10:57 PM
egb18c5's Avatar
you need to search, your answer to your question is here:
http://www.c-speedracing.com/h...c.php
and for all your other questions https://honda-tech.com/zerosearch
Old Nov 22, 2007 | 07:12 AM
Default Re: ls vtec compression ratio? (egb18c5)
the c speed calulator isnt perfectly accurate, but it will give you a good idea.
Old Nov 22, 2007 | 07:17 AM
girliehonda's Avatar
i say go with b16 pistons or ctr if i were you. i went with gsr piston which is around
10.0-10.5 compression ratio on a stock gsr head. and i just made 180hp and 129tq on crome.
my setup
stock gsr head
skunk2 stage 1
m factory cam gears
jvt 4-1 header
catco 2.5 in and out
thermal r & d catback
b18b bottom
ls rod
arp rod bolts and head studs
vtec was set at 5000rpm
well i hope this will help. overall it depend on budget and what you plan to do with it. good luck
Old Nov 22, 2007 | 08:50 AM
Default Re: ls vtec compression ratio? (girliehonda)
ctr's are not a good idea in an ls block because you will be looking at well above 12:1, and in my eyes, and asston of research, 12:1 is just about the perfect street comp ratio.
Old Nov 22, 2007 | 01:32 PM
Default Re: ls vtec compression ratio? (killerpenguin21)
ok well i have decided to go with the p30sand stock ls rods with arp rod bolts. o and compression should be 11.7:1
Old Nov 22, 2007 | 02:08 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote"> and in my eyes, and asston of research, 12:1 is just about the perfect street comp ratio.</TD></TR></TABLE>
I would argue that roughly 11.5:1 is the best comp ratio for the street unless you're running cams that require more.
Old Nov 26, 2007 | 07:35 AM
Default Re: ls vtec compression ratio? (00Red_SiR)
oh and does anyknow if i can use my ls injectors with the obd2 ecu and stuff since pretty much everything on te car will be obd2
Old Nov 26, 2007 | 02:45 PM
00Red_SiR's Avatar
All Motor Mentor
your injectors have to match the wire harness, if they do, they'll work.
olskoolhatchy
May 7, 2008 12:56 AM
olskoolhatchy
May 6, 2008 03:28 PM
EF8KiLLaBeE
Jan 21, 2006 10:37 AM
lsvtec92teg
Jan 4, 2005 05:38 AM
InfamousRS
Oct 30, 2001 03:11 AM
