ITR Camshafts
Old Nov 20, 2007 | 11:17 AM
the_one_6682's Avatar
Default ITR Camshafts
I ordered some ITR cams from ebay......and now my car wont stay running at idle....and it seems to be misfiring....kind of like the car is out of time....but the thing is all timing marks line up.....timing belt is on time.....anybody ever have this issue with cams before?? possibly the wrong/messed up cams.....
Old Nov 20, 2007 | 12:01 PM
eyeranik's Avatar
Default Re: ITR Camshafts (the_one_6682)
double check your timing. same thing was happenin on this crx my buddy has. turns out that TDC was a different than how it looks. he was actually a few degrees retarded. i'll get the full completedetails from him adn get back to you.
Old Nov 20, 2007 | 12:43 PM
Default Re: ITR Camshafts (eyeranik)
I did check my timing...and it appears to be on...let me know what happened with your buddy's crx...
Old Nov 20, 2007 | 01:54 PM
distributor could be 180 degrees off.
put motor to top dead center,take distributor off and make sure the 2 lines are parallel.
Old Nov 20, 2007 | 07:54 PM
Dogginator's Avatar
Daisy... Daisy...
Did you use the white or red mark to find TDC? The white mark is correct.
Old Nov 20, 2007 | 08:18 PM
steven_highet's Avatar
Default Re: ITR Camshafts (Dogginator)
Get a degree wheel and a dial indicator. This is the only way to accuratly phase your cams correctly with your crank. The marks should only be used as a visual referance. There are kits out there that you can by that has everything you need to phase you cams right
Old Nov 20, 2007 | 08:29 PM
mx621's Avatar
Default Re: ITR Camshafts (steven_highet)
check the valve lash???? , then
flushsi
Jun 12, 2011 06:12 PM
elusive123
Jan 1, 2005 12:24 PM
95 Gizzer
Feb 17, 2003 03:08 PM
