Skunk2 Front/Blox rear camber kits
I have had a Skunk2 Pro series camber kit for the front lying around for a few months now and I am going to have some free time next week to install it.
The kit has the appropriate fittings for where the arms connects to the strut but the bushings for connecting to the body of the vehicle are not present. Can I use the old bushings from the stock upper control arm or am I going to have to call Skunk2 and order them?
I also have a Blox rear camber kit composing of 2 upper control arms. I noticed that the rubber bushing that is between the 2 areas that bolt to the body of the car do not move, is this supposed to do this?
Thanks in advance!
Brian
Thanks in advance!
Brian
The upper control arm bushings for 96-00 Civics should be the same size as the ones in your Skunk2 arms, but who knows for sure. You'll need a vise or something similar to press the bushings in and out.
IntegraFanatic
Apr 6, 2004 11:15 AM
GreenBean
Nov 29, 2002 06:29 AM
