Spoon Termo Switch
Old Nov 20, 2007 | 09:23 AM
Rishiras's Avatar
Default Spoon Termo Switch
Guys,
I received a Spoon Termo Switch (part # 37760-Ek9-G00) from Japan as a present.
I want to install this on my Dc2 ITR JDM 99.
My question is> what will this do to my car, what will it help me with ?
I basicly have a allmotor setup, B18C JDM ITR, 4.785 finaldrive etc tranny, Mugen Intake, 4-1 headers, and Catback.
Regards,
Rishi
Old Nov 20, 2007 | 09:37 AM
Padawan's Avatar
Darth ModerVader
Default Re: Spoon Termo Switch (Rishiras)
It lowers the temperature at which the radiator fan(s) is activated.
Old Nov 20, 2007 | 09:43 AM
Rishiras's Avatar
Default Re: Spoon Termo Switch (Padawan)
Is that bad ? performance wise?
R
Old Nov 20, 2007 | 10:00 AM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishiras &raquo;</TD></TR><TR><TD CLASS="quote">Is that bad ? performance wise?
R</TD></TR></TABLE>
someone correct me if Im wrong.
in some cases it may take longer for the car to get to full operating temperature. in extreme cases it may prevent the car from reaching full operating temperature. it also may make the fan run non-stop because the car will never cool off enough for the fan to go off. and I think you are supposed to use a fan switch in combination with a cooler thermostat as well.
Old Nov 20, 2007 | 10:03 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Spoon Termo Switch (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
in some cases it may take longer for the car to get to full operating temperature. in extreme cases it may prevent the car from reaching full operating temperature. it also may make the fan run non-stop because the car will never cool off enough for the fan to go off. and I think you are supposed to use a fan switch in combination with a cooler thermostat as well. </TD></TR></TABLE>
With the 160 degree thermostat there was certainly a problem with the car not reaching operating temperature, but with the thermoswitch it is not.
Old Nov 20, 2007 | 10:26 AM
Rishiras's Avatar
So what is this swith for ? what else is needed then for a total perfect combination?
And durting 1/4 mile what will it help me with?
R
Old Nov 20, 2007 | 10:38 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rishiras &raquo;</TD></TR><TR><TD CLASS="quote">So what is this swith for ? what else is needed then for a total perfect combination?
R</TD></TR></TABLE>
It's essentially intended as a sort of "upgrade" to the cooling system. It can be combined with a lower temperature thermostat and/or a high-pressure radiator cap, but it doesn't need to be.
You really are not going to see any performance benefit from it, especially not on a 1/4 mile strip.
Old Nov 20, 2007 | 11:11 AM
itr1244's Avatar
no. i'd say it's not gonna help you with any 1/4 mile time improvement.
Old Nov 20, 2007 | 12:55 PM
mist sITR's Avatar
Default Re: Spoon Termo Switch (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">no. i'd say it's not gonna help you with any 1/4 mile time improvement.
yeah and probably spoons least "BLING" part.
for 5$ in parts i wired my radiator and A/C fan to switches inside my car so i can flip em on whenever i want and run the A/C fan without the A/C being on.
Old Nov 20, 2007 | 03:58 PM
ontheroad's Avatar
Default Re: Spoon Termo Switch (mist sITR)
Usually when a motor reaches too high temperatures as a result of intensive driving, its performance decreases a bit. So I think the thermo switch can prevent from reaching such high temperatures, but it will not be useful at all on a 1/4 mile...
AntMan401
Aug 23, 2006 05:08 AM
ArmyGreenITR
Dec 16, 2003 10:23 AM
snowboarderguy44
Oct 14, 2003 01:17 PM
underrated99si
Jun 20, 2002 06:06 AM
ithrowpoop
Apr 3, 2002 05:14 PM
