prob with my windows
my window keeps coming off track in my 93 civic ex. i took the door apart and i couldnt really see anything obvious. the window also goes down very hard sometimes, but smooth as a knife thorugh butter other times. its like one side of the window goes up too fast then binds at the top and leaves a big space at the other end. thx
i greased it up good while i was in there but it still does it. its like the peices inside are all wobbly. i tried to see if there was something to tighten but i couldnt see much. thx
there are bolts that hold the glass still, could be that those bolts are loose. Also try what sleeperrex suggested...worst comes to worst you might need a new window regulator but i from your info it doesn't sound like thats the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxricer66 »</TD></TR><TR><TD CLASS="quote">i could get to one bolt and it was tight. the other one i couldnt get to so idk if it was loose. thx. i tired the spray already.</TD></TR></TABLE>
you have the roll the window up/down to get the right angle to see the bolt.
ya i tried it, there was no open hole on the other side of the window. if u are looking at the door, there is a bolt on the left side of the window and one on the right side. i got the one on the left, but there was no space on the right. thx for the help
Might have to change your regulator if it keep coming off the tracks.
To get to to the right side of the bolt you need to raise to a point where you can reach to it on the right side. I don't if the inner doors are the same as the EK?
window regulator is rarely the issue here. please dont get one unless u know that is the problem. most of the time its the run channel that needs to be replaced cause it got a lil bent and now this happens.
The same thing happens to my driver side window. The regulator feels and loose and sht rite? so does mine and its brand new from honda. I have to pull up the front of the glass for the window to get a good seal and no get air noise.
I dont fall off the track anymore cause of the silicone spray, but i need new run channels for the window to seal properly. Same thing in ur case im assuming.
