FS: mini cooper s race car scca loaded to much to list 300hp
Endyne Head - this is the nicest head I have ever seen and I have worked with all of them, Jesus Heads, Cosworth Heads, Custom builds, Fireball, etc., This sucker has .5 oversized intake and 1mm oversize exhaust valves. There are over 30 hours of porting and polishing that I had done here, in house. I watched it go from the usual port and polish to a free flowing mirror finish. Unbelievable!!
Shrick Race Cam
Endyne Supercharger - theoldone.com- This thing is WICKED!! As you can see they weld up the air relief ports which gets you a little more boost. The only downside here is that it creates a louder supercharger. I think it sounds awesome though, like a true hot rodded supercharger should sound.
19% Supercharge Pulley - Why go with any less???
0% Lightweight Crank Pulley
Madness Stainless Header- It\'s a little loud but WOW does it flow!!
Alta Catback Stainless Exhaust - I went with 4 other exhaust systems before deciding this was the best out there and it looks great too!! Sure it was pricey but why settle for 2nd rate parts that everyone else is using?
Alta Cold Air Intake with Blue Silicone Intake Hose
Poly Motor Mount Bushings
2005 Transmission - close ratio 6 speed, Big improvement over the earlier trannies.
Lightweight Flywheel
Stage 2 Clutch
Quaife Limited Slip Differential
Madness Water to Air Intercooler - This is great for keeping the Supercharger as cool as possible and also looks very trick. You\'ve got the sick looking polished top mount intercooler, the front mount additional intercooler, all the blue silicone hoses and a stand alone electric water pump. There\'s also the ultra cool Billet overflow tank on the firewall. Also includes and onboard temp gauge which can monitor both in and out intercooler temps. It is mounted just under the center console area, youll see it in the iterior pics!
JCW Cooper Works Bumpers - Front and Rear - Who wants to look stock??
Orciari Side Skirts
Zeemax 3 Piece Wing - Awesome!!
Zeemax Cowl Air Snouts
Zeemax Hood Scoop
05 Xenon Headlights with Blue Protective Film
Aero Grills
Black Powder Coated Gas Door
Blacked Out Door Handles
Blacked Out Belt Line
M7 Carbon Fiber Front Adjustable Splitter
Front & Rear Tow Hooks
Shaved Corner Lights Front & Rear
Carbon Fiber Rear Hatch Handle
Huge Panoramic Dual Pane Glass Sunroof
Leda Fully Adjustable Coilover Suspension - Not only can you raise or lower the car to your preference with ease but there is a **** on each strut body which allows you to adjust the firmness. You simply turn the **** to give the car a softer or firmer ride. These were nearly $3,000 from Madness. Check out the site, Italian Suspension at its finest!!
Madness Adjustable Camber Plates
Madness Fully Adjustable Rear Control Arms - Upper & Lower
Madness Adjustable Rear Sway Bar
Stop Tech/Brembo Big Brake Package with Huge 4 Piston Calipers & Slotted Oversized Rotors all the way around - Can you say \"Stops on a Dime\"?
Team Dynamics 17\" Rims with Yokahoma Tires - I will include center caps. I prefered the no center cap look myself
Ferrari Air Horns
Alta Short Throw Shifter
Whalen Shift ****
Alta Fully Adjustable Drop Links
Odyssey Super Small Lightweight Batter in the Relocated Battery Compartment - This little sucker holds a charge way better than the huge heavy stock battery ever did. It even surprised me!!
06 Tail Lights - I Love Em!!
John Cooper Works Carbon Fiber Dash - WOW!!!
Black & Blue Heated Leather Seats with Blue Carpet
06 Cooper S Black Headliner & Pillar Kit - Looks Awesome!!
Custom Roll Cage - Functional for safety and still allows for full use of the rear seats in up or down position.
Momo 12\" Steering Wheel & Hub - This is one of my favorite parts of the car. It allows for such precise steering - You\'ll never want to go back to your big semi truck steering wheel again.
Boost Gauge with Real Carbon Fiber Pod - Sits next to the Tach.
Custom Made Black & Blue Leather E Brake and Shifter Boots
Left & Right Glove Box Shelves
Rear Cargo Shelf with Mini Storage Tote & Net
MiniFini Armrest with Storage Area
Fully Loaded Tool Kit
Blue Fire Extinguisher - Mounted under the left rear window
All of the Dash/Interior LED lights have been painstakingly replaced with Blue LEDs - This looks incredible!!
I also wanted a great sound system but didn\'t want to take up any of the Minis valuable cargo space for amps and subs, etc, so I improvised and ended up with a great sounding set up that includes the following!!
Rockford Fosgate Power Amp - The amp is mounted behind the right airbag cover in place of the airbag
Memphis Audio 6 1/4\" Kevlar Component Speakers with 1\" Tweeters and Crossovers - in the doors - These were pricey but I didn\'t want to compromise!!
Alpine Amp - Mounted out of the way, under the right seat.
JL Audio VR Series 6X9\'s - in the rear stock speaker location. I didn\'t want to waste space on a sub and was told by numerous Audio Professionals to use these JL\'s. Honestly you would think by the sound that there is a sub in the back.
Ipod Hook Up in the Glove box
Alpine 9856 CD Player/Tuner/Ipod Controler - This thing is great, not only does it light up in blue to match all of the other dash lights but you can use it to control your Ipod!! The volume **** doubles as an Ipod jog dial.
Color Matched Harmon Kardan Speaker Covers - Front & Rear
JCW Checkerboard Floor Mats - I will also include a set of thick rubber winter style Mini mats as well and a set of the stock cloth mats.
Last but definately not least is the custom paint!! I have always loved the dark silver, that\'s my favorite Mini color but I needed something a little extra. I decided to go with House of Kolor, Ultra Mini Rainbow Flake Powder in the 1st coat of clear. You really need to come see it in person to appreciate it. Neither my description or pics do it any justice. It looks like the normal Dark Silver but when the sun hits it - BAM!! It takes off into all the colors of the rainbow from the light hitting all of these little microscopic flakes. It is nothing short of awesome. I get compliments on the paint constantly!!
Between the cost of the car, all of the parts, the 100\'s of labor hours spent, the paint work, the countless time invested in wet sanding, buffing and so on, I have receipts which add up to over $50,000. This is the deal of a lifetime for the right person!! Obviously, if you don\'t want people staring, pointing and or drooling then this car won\'t be your cup of tea. This is a real attention getter so buyer beware. I get compliments from everybody - whether they are 8 years old or 80 years old everyone gets a kick out of checking this car out.
Everything on the car is in great shape. There\'s no worn out clutch, no balding tires, no thinning brake pads, etc,. I have taken very good care of this car. It is always garage kept and hasn\'t spent a night outdoors since I have owned it. It is never dirty, I can\'t stand a dirty car!! I don\'t beat on my stuff Non-Smoking car so no burn holes or stinky stink!!
Like I said, don\'t let the fact that it\'s customized scare you, it is still as user friendly as a stock mini, if not more. The only differences I can think of are the water to air intercooler is going to need to be topped off with coolant whenever you do your normal radiator check. And the stereo will take you about 15 minutes to figure out if you are using it to run your ipod. I am including the Alpine factory manual so its not that big of a deal- well worth it when you see what all this thing can do!!
THe pics I have, Most of which don\'t do the car justice. It think it is impossible to capture a good shot of the exterior finish. The interior pics showing the blue LED lights are not great. The pic was taken during the day so it just doesn\'t show the true blue glow of the lights. Let me know if there are any specific areas you would like to see more of and I can send pics.
vehicle has a utah rebuilt restored title which is up for inspection to pass for a clear title.
Shrick Race Cam
Stage 2 Clutch
Orciari Side Skirts
Zeemax Hood Scoop
Aero Grills
Ferrari Air Horns
Whalen Shift ****
Turbolife93
Jun 18, 2019 03:39 PM
310BHPB16
Aug 26, 2005 07:47 PM
