Question about Replacing Brakes on 99 Accord 4cyl
Old Nov 19, 2007 | 11:11 PM
Donboss's Avatar
Default Question about Replacing Brakes on 99 Accord 4cyl
I needa get new brakes and rotors and i was wondering what i needa get...
front/rear rotors and front/rear brake pads?
front rotors and front/rear pads?
thanks
Old Nov 20, 2007 | 03:39 AM
YeuEmMaiMai's Avatar
Default Re: Question about Replacing Brakes on 99 Accord 4cyl (Donboss)
unless your rotors are toast all you need to do is turn them and put on new pads and lube up the calipers with high temp grease. prolly wouldn't hurt to use anti squeak on the shims and backs of the pads
Old Nov 20, 2007 | 12:27 PM
Donboss's Avatar
ok so would i needa get front rotors only? or front and back?
Old Nov 20, 2007 | 02:04 PM
Default Re: (Donboss)
neither if your rotors are good and need to just be turned (cut on a lathe)
Old Nov 20, 2007 | 03:13 PM
The-Kid's Avatar
Default Re: (YeuEmMaiMai)
How bad are they? So bad that there are scored marks on it. (little grooves?) I would get them refinished. But if you want some rotors. You can replace it with some brembo blanks or get one from Kragen. They are pretty good. I would go for any ceramic brakes. I used Kragen's "Satisfied" brand.
And doing some brake maintenance (lube clean) really does help with usage. So do it!
kevinm1981
Aug 3, 2009 02:24 PM
Donboss
Nov 10, 2007 10:25 AM
R81_DC2
Mar 30, 2007 10:23 AM
skimeast1982
Oct 18, 2006 04:31 AM
AznBlueBoy
Jun 18, 2005 10:03 AM
