My First Big Build Im only 14
HEAD:
Supertech Valvespring & Retainer-Got Already
Supertech High Comp. Valve n Valve guide
Bored GSR TB
Blox GSR IM-Got Already
Blox HSL Cam-Got Already
Port & Polished
Intake Manifold Gasket n TB
Viton Valve Seal
BLOCK:
Shotpeen LS Rods
New OEM .25 OS JDM P30 Pistons
New OEM Piston Rings
Fresh Bore & Hone
ARP Rod Bolts-Got Already
Micropolished Crank
Balanced Bottom End
GSR Girdle
Tranny
GSR Tranny-Got Already
Exedy Stage 2 Clutch
Exedy Flywheel
the stuff i dont have yet so i keep it or chnage it ?
waht else should i get ??
should i go B16 Head or GSR ???
Bored GSR TB
Port & Polished
Viton Valve Seal
BLOCK:
Shotpeen LS Rods
Fresh Bore & Hone
Micropolished Crank
Balanced Bottom End
GSR Girdle
Tranny
Exedy Flywheel
How old do you have to be to get a driver's license in TN?
I rebuilt my first engine (Audi) during the summer between 8th grade and high school. Good luck with this build.
Permit at 15, restricted license at 16, unrestricted at 18.
Sometimes you can get a hardship license at 14, but that is only for work/school.
What block and crank are you using, Im assuming your planning an lsvtec build, if so, do a search for "bambams" how to build a realiable lsvtec, that thread is exactly what you and everyone who's planning a lsvtec build should follow. I remember when i was 14 i already had enough money from working with my dad doing construction work to pay for my own car and mods, keep up the research and take your time and have fun with the build, good luck
Your profile says you are 18
does not work well here on HT. And GSR615 sounds like one of those names on "To catch a Predator"! Only real talk here kid
14 damb around here your barely aloud to bag groceries nevermind drive........sounds like you've done some research keep up the good work and hope the build goes well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrob »</TD></TR><TR><TD CLASS="quote">If you already have the Blox intake manifold for a gsr you may not want to get a B16 head since it isn't going to fit. You will end up buying a new head and intake manifold...</TD></TR></TABLE>
i got a gsr head n B16 lol but the b16 needs to be resurface
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR615 »</TD></TR><TR><TD CLASS="quote">
what kind of header best ?
and any body selling any parts that i need ?</TD></TR></TABLE>
look ^^ up there SMSP
and i have a set of skunk2 pro2 cams for 500 shipped lmk
i got a gsr head n B16 lol but the b16 needs to be resurface</TD></TR></TABLE>
All I am saying is if your Blox manifold is made for a GSR head, it is NOT going to fit your B16 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR615 »</TD></TR><TR><TD CLASS="quote">iC i kno i goin to use a gsr head but i need some piston i want to go for P30</TD></TR></TABLE>
Please dont talk in txT
On a better note...Top stuff dude, its great to see a person your age getting into there car's !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris1741 »</TD></TR><TR><TD CLASS="quote">Like said above....just don't drive like a moron. And how are u going to drive at 14 anyways?</TD></TR></TABLE>
i bout to try 15 and anyway i will drive when i get my license its not like im going to finish the build that fast it going to take my a while cuz i don't have a job or anything okay
thank for all the comments
HEAD:
BLOCK:
Shotpeen LS Rods
New OEM JDM P30 Pistons
Micropolished Crank
Balanced Bottom End
GSR Girdle
does anybody got those ^ parts for sale ??
or kno about how much its goin to cost for the machine work for those parts ?
HEAD:
BLOCK:
Shotpeen LS Rods
Micropolished Crank
Balanced Bottom End
GSR Girdle
