P0135 O2 SENSOR
Old Nov 19, 2007 | 05:23 PM
kraaaaap's Avatar
Default P0135 O2 SENSOR
I just had a question about the P0135 O2 SENSOR.
What is it's function? Is it recommended to fix immediately? Can it damage your car severely?
Thanks.
Old Nov 19, 2007 | 05:45 PM
IMALLSLO's Avatar
Default Re: P0135 O2 SENSOR (kraaaaap)
Oxygen sensor monitors air/fuel ratios and sends data to the PCM. Should you replace it? Yes. It can cause a lean or rich condition if its reading improperly. Will it hurt the car? No but it can hurt gas mileage and performance.
Old Nov 19, 2007 | 05:48 PM
abusedhusband's Avatar
Default Re: P0135 O2 SENSOR (IMALLSLO)
{Oxygen sensor monitors air/fuel ratios and sends data to the PCM. Should you replace it? Yes. It can cause a lean or rich condition if its reading improperly. Will it hurt the car? No but it can hurt gas mileage and performance.} x2
Old Nov 19, 2007 | 10:01 PM
kraaaaap's Avatar
THANK YOU.
AND BY ANY CHANCE DO YOU GUYS KNOW HOW MUCH IT COSTS TO FIX OR REPLACE?
Old Nov 21, 2007 | 07:07 PM
depends on where you go. i know the sensor is alot of $. but i found a place local to me thats pretty cheap. cant remember how much tho.
Old Nov 21, 2007 | 07:35 PM
Neebs's Avatar
Its easy to replace the O2 sensor. O2 sensor goes round around 60-80 bucks.
I suggest your replace unless you want bad gas mileage.
Skunk2DC2
Jun 2, 2012 03:24 PM
ruffrhyder
Engine Management and Tuning
Sep 25, 2008 07:56 PM
importdude2000
Dec 16, 2004 11:45 AM
hondave
May 2, 2004 09:36 PM
ironchef25
Feb 3, 2004 04:32 PM
