FS: 2JZ partx cheap! garage clean out!!
ALL PRICES ARE "OBO" = or best offer
Contact Email: <u>JackyPerformance@yahoo.com</u>
TE-44 Turbo Blanket (to4e size) =: $40
New (never used) Mercedes 240D brake rotors: $8
<u>All the following parts are from a 1995 Lexus SC300 car w/ ~97,000 mileage. I have MANY bolts/screws/brackets, etc and will be including whatever accessory I have that retains to the part being purchased. So, we're talking about a 1995 Toyota 2JZ-GE engine and parts:</u>
SC300 stock Shocks & Springs: $160
2JZ-GE stock Exhaust manifold (2 pieces): $25
5.7psi Tial 38mm & 40mm wastegate spring: $13
7.25psi Tial 38mm & 40mm wastegate spring: $13
8.5psi Tial 38mm & 40mm wastegate spring: $13 (not in picture)
1995 Lexus SC300 02 sensors (2): $19 each
6 oem Injectors: $65
Fuel Rail: $33
1) 1995 Lexus SC300 Front Brakes (completely loaded) with Front Rotors: <u>$100 </u>
All brake parts are original from the car(except pads = aftermarket) and function perfectly. Rotors have been freshly resurfaced (a lot of life left) and aftermarket pads have ~50% life remaining.
Timing Idler Gear Pulley (including bolt): $30
Timing Idler Gear Pulley: $25
OEM Hood Support Shocks: $50
1994 Lexus SC300 Auto ECU: $90
Camshafts Cover: $9
Lexus SC300 Mufflers: $27 for both!
AC Recharge Kit: $10
Distributor w/ cap and spark plug wires: $50
SC300 wheels + tires + spare: $200
bad road rash on one of the sc300 wheels, but I'll still include if buyer wants it, thus making it 5 wheels + tires. I'm including all 4 lexus center caps even though they're not pictured.
Lexus SC300 / mkiv Toyota Supra NA clutch kit: $20
cheap candidate to have your clutch rebuilt costing less than new clutch
Misc Lexus SC300 heat shields: $6
oem exhaust manifold heat shield:
misc exhaust heat shield:
Flywheel for Toyota Supra mkIII (7mgte) R154 5 speed transmission: $30
AC-Delco and Sears Jack-stands + Jack Package: $22
Modified by MiNcEdMeAt at 8:25 PM 11/19/2007
Fuel Rail: $33
Camshafts Cover: $9
teler86
Sep 2, 2008 12:55 PM
