Timing Belt Tensioner Pulley Bolt issues
Old Nov 19, 2007 | 03:42 PM
ohdannyboy111's Avatar
Default Timing Belt Tensioner Pulley Bolt issues
Just recently I noticed my timing belt was walking right off it's gears, unfortunately I noticed it after it was 1/3 devoured and had skipped a tooth . Anyway, after removing the plastic timing covers and all I found the bolt that the timing belt tensioner pulley pivots on was broken off flush w/ the oil pump cover .
So far I've removed the engine (It's about time to reseal it anyway) but I can't even punch a centerhole in the remains of the bolt to start drilling it outta there, do any Honda techs out there have any suggestions?
Old Nov 19, 2007 | 04:43 PM
Sampsonite987's Avatar
Default Re: Timing Belt Tensioner Pulley Bolt issues (ohdannyboy111)
Why can't you punch a center on it, is it not flat enough or what?
Pics?
Old Nov 19, 2007 | 05:11 PM
Default Re: Timing Belt Tensioner Pulley Bolt issues (Sampsonite987)
Thanks for the reply, actually the punch I used was pretty cheezy, and the bit I tried to begin drilling with wouldn't scratch the surface. So maybe I should re-post after some worthwhile tools are sourced, lol.
But I guess what I'm really looking for before I spend too much time trying to extract this bolt (because they're installed w/ a loctite type compound from factory) is confirmation that extracting it is worthwhile.
Iwould be a blessing and a curse to hear that I should replace the whole pump cover, but at the same time extracting guffed-up and loc-tite'ed bolts isn't so pleasant either, so really anyone w/ prior experience on this particular issue please post. Otherwise I'll just get a punch and drill bit that aren't as old as me.
Old Nov 19, 2007 | 05:14 PM
Yeah I had to punch and drill a crank bolt just recently and it came out with no problems, although the crank bolt is a little bigger and easier to grab. That's what I would try.
Old Nov 19, 2007 | 05:33 PM
Thnx
Old Nov 19, 2007 | 06:37 PM
Just got it out, found a decent punch and drill bit, ditched the cheepo's. Take care of your tools people, they'll take care of you
Old Nov 19, 2007 | 06:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohdannyboy111 &raquo;</TD></TR><TR><TD CLASS="quote">Just got it out, found a decent punch and drill bit, ditched the cheepo's. Take care of your tools people, they'll take care of you </TD></TR></TABLE>
methos713
May 5, 2008 08:01 PM
teler86
May 18, 2006 06:29 PM
spooncivic1
Oct 4, 2004 06:03 PM
Shady Hills
Jul 24, 2004 09:40 PM
SPL KID
Apr 17, 2004 01:14 PM
