Got a few questions.
Old Jun 24, 2002 | 06:51 PM
JDMITR222's Avatar
Default Got a few questions.
Will a 98 USDM ITR ECU work on a 00 B16?.Will a ITR radiator fit on a 00 Si?.and will a GSR distributor work on a B16?.Any help will be greatly appreciated.
Thanks again
Justin
Old Jun 24, 2002 | 06:56 PM
poison's Avatar
Default Re: Got a few questions. (JDMITR222)
yes, yes, and i believe so
Old Jun 24, 2002 | 08:59 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Thanks again
Justin
1. Not without a jumper harness. The plug style changed from 1998-1999. Still OBD2, but a different plug is on the 1999-2001 stuff as opposed to the 1996-1998 OBD2 stuff.
2. REmove your A/C condensor and sure you can use the ITR radiator, but WHY? The Si radiator is dual-core - might not be as good as ITR, but plenty sufficient for any B-Series motor really.
3. GS-R will work, but what years are you talking about? OBD2 can be used on an OBD1 motor and vice versa, but the coil wires will have to be moved depending on which way you're trying to go. Same style though? Bolt it up and you're set.
Good luck to you. What are you trying to do anyways?
Old Jun 25, 2002 | 09:11 PM
JDMITR222's Avatar
Default Re: Got a few questions. (B18C5-EH2)
Well the reason i'm doing this is because i have these parts laying around and i'm thinking of buying a stripped/salvaged SI.From an auction yard.So i have a 97 GSR distributor,ITR radiator,98 ITR ECU.To make this car run these are the parts it needs.I don't want to have to go and buy parts if i can use what i have now if possible.
Also it needs a cluster,hood,fenders,headlights,bumper,rear spoiler.If anybody you that you know of has these please let me know.
Thanks again
Justin
Draggin99Si
Jan 18, 2006 07:36 AM
sinister357
Apr 19, 2005 12:15 PM
B-money
Jul 29, 2004 06:15 PM
austrian type-R
Mar 9, 2003 03:45 PM
bruthaboost
Jul 3, 2002 10:33 AM
