CEL 95 civic
CEL is solid and SRS light is flashing constantly when retrieving code. SRS light is off when not retrieving code. Does this mean something is wrong with the SRS, ECM, or not storing code? I checked to see if a code can be stored by disconnecting the oxygen sensor and it gave me just the oxygen sensor code. I reset it and still get a solid CEL and flashing SRS. Any suggestions will be appreciated. Thanks
When you jump the 2 pin connector the srs light flashes and the cel doesn't? That's o2 sensor, change it reset ecu and the cel will be off. Nothing is wrong with the srs system.
bright rider
11
Feb 28, 2007 12:43 PM
