AEM Tru-Time Cam Gears
Old Nov 19, 2007 | 02:51 PM
VTecLude1994's Avatar
Default AEM Tru-Time Cam Gears
A friend of mine recently sold his Prelude and he gave me his cam gears. I've seen a few threads throughout my days on H-T within the Prelude forum where people talking about their cam gears slipping. Could this be because of incorrect installation or does this regularly happen? Throughout my searches basically I have seen it is pretty much worthless to install cam gears on stock cams. With my mods listed below would I be wasting my time installing these?
112k H22A1
AEM CAI
Megan Header /w 2.5" collector
Megan Test Pipe
Tsudo 2.5" Catback
Exedy Stage 1
Fidanza 8lb Flywheel
Untuned V-AFC(maybe upgrading to Hondata in the near future)
Old Nov 19, 2007 | 03:16 PM
AndyD's Avatar
Default Re: AEM Tru-Time Cam Gears (VTecLude1994)
The "gains" aren't worth the time to install or the risk that they might slip.
Old Nov 23, 2007 | 07:25 AM
vlang29's Avatar
Just make sure the bolts are tight. If you still have problems with them slipping use Post-assembly loc-tite and put a drop where the outer ring and the inner part of the gear meet.
Old Nov 23, 2007 | 07:31 AM
vlang29's Avatar
Default Re: AEM Tru-Time Cam Gears (vlang29)
Oh and Gains... At the track, I Showed CONSISTENT 3-4 MPH 1/4 mi gains. And an average 1mpg better mileage. Cam Gears are really fun to play with if you know where to set them. You can switch from screamer to a torque monster in 5 minutes!
However.. Dont just slap them on and start cranking on them. You can try one degree at a time, and use a g-tech or something similar to get a ballpark. But definately don't advance or retard more than one or two degrees until you get it on a dyno. A dyno is the only way to maximise hp from the gears.
betta285
Jun 12, 2007 03:26 PM
digital sol
May 2, 2006 04:11 PM
JFG Kevin
21
Dec 8, 2004 08:30 PM
Edulerp
Jun 26, 2004 03:07 PM
JdoggsGSR
Jul 4, 2001 08:43 AM
