How to Tell? -EP3 Specific- Koni Yellows = 55mm or 50mm?
Old Nov 19, 2007 | 12:59 PM
WyldRice's Avatar
Default How to Tell? -EP3 Specific- Koni Yellows = 55mm or 50mm?
i am ordering the long awaited Koni Yellows, but i don't know the dimentions.
i have two choices for the EP3 -almost all sites ask if it's 50mm or 55mm
HOW DO I find out what mine is?
UPDATE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">01-02 have 50mm and 04-05 have 55mm.
2003 models are different. youll need to measure them...</TD></TR></TABLE>
Modified by WyldRice at 4:25 PM 11/21/2007
Old Nov 19, 2007 | 01:17 PM
OSK Automotive's Avatar
Default Re: How to Tell? -EP3 Specific- Koni Yellows = 55mm or 50mm? (WyldRice)
Measure them with calipers. If you don't have calipers, you could take a piece of string and wrap it around the strut and than measure how long the string is (not as accurate obviously).
Old Nov 19, 2007 | 02:22 PM
WyldRice's Avatar
Default Re: How to Tell? -EP3 Specific- Koni Yellows = 55mm or 50mm? (OSK Automotive)
THANKS! ok, i will RELUCTANTLY do the string method... i hate getting dirty!
UPDATE- <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">01-02 have 50mm and 04-05 have 55mm.
Modified by WyldRice at 4:23 PM 11/21/2007
Old Nov 19, 2007 | 03:02 PM
Todd00's Avatar
I said I don't want a title!
What year is your car? Good rule of thumb is that 02 = 50mm and some of the 03's = 50mm.
04-05 was 55mm.
I believe all of this is in the FAQ somewhere
Old Nov 19, 2007 | 03:35 PM
WyldRice's Avatar
Default Re: How to Tell? -EP3 Specific- Koni Yellows = 55mm or 50mm? (Todd00)
ok osk, my keyboard is greasy as hell now, and no luck finding it- i measured the tubing (Nowhere near the 50mm or 55mm)
update- <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G &raquo;</TD></TR><TR><TD CLASS="quote">01-02 have 50mm and 04-05 have 55mm.
Modified by WyldRice at 4:22 PM 11/21/2007
Old Nov 19, 2007 | 06:29 PM
Did you divide by Pi (3.14)?
-edit-Maybe I should've explained more. Take the measurement of the string (the circumference) and divide that by Pi (3.14) to get the diameter. So it should be something like this....
I got this from a old thread on 7thgencivic.com (now known as civicforums)
"If the string measures 157mm, then divided by 3.14 you get 50mm
If the string measures 172mm, then divided by 3.14 you get 55mm"
Old Nov 19, 2007 | 10:22 PM
WyldRice's Avatar
OK, That makes WAY more sence!
im a noob
Thanks again!
Cheers!
EDIT+ Also- Todd,
i scoured the globe (of HT archives) and found this... you were seeing if an RSX Suspension would work on an '01-'05 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efficiencyJunkie &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone confirm thie ...
Quote- ToddOG "...you will need to determine if you have a 50mm or 55mm front strut to get the correct insert.
Not 100% positive, but 01-02 Civic = 50mm, 03-05 = 55mm."
i guess nobody ever verified it- so i hit it with a bump... maybe it will get confirmed someday
https://honda-tech.com/zerothread?id=1715937
this is usually what happens when i search for hours...
Dead End! with NO confirmed answers
that's why i ask so many "Noob" questions
Modified by WyldRice at 10:49 AM 11/20/2007
UPDATE! GOT AN ANSWER FROM C_G
i sure Hope this helps someone other than just me!
Thanks Guys!
Modified by WyldRice at 4:20 PM 11/21/2007
.I.Need.Money.
Suspension & Brakes
31
Feb 1, 2007 09:24 PM
95gsrhead
Suspension & Brakes
12
Dec 5, 2006 11:52 AM
aandrewcc
Suspension & Brakes
Feb 16, 2006 08:57 AM
projectac
Suspension & Brakes
17
Dec 1, 2005 10:42 AM
urbanlegend21
Sep 2, 2004 06:29 PM
