alternate way to installing arp extended studs
Old Nov 19, 2007 | 11:24 AM
timmy0tool's Avatar
Default alternate way to installing arp extended studs
i know a press is ideal when installing arp extended studs but is there another way to do it?
i can remove the stock studs using a mini sledge hammer but when installing the extend studs can't you just do this:
-put the stud through the back of the hub
-put a spacer on the front side (i.e. a larger diameter lugnut)
-thread in a lugnut on the front side
-tighten down with an impact wrench until stud is seated properly
order: stud, hub, spacer, lugnut, impact wrench
i know you risk stripping the knurls off the stud but wouldn't that work?!
Old Nov 19, 2007 | 11:38 AM
95ProjectEJ1's Avatar
Default Re: alternate way to installing arp extended studs
Im almost positive that there is a write up on this and all they used a BFH and also tightened the lug nuts until it seated the studs
Old Nov 19, 2007 | 11:50 AM
timmy0tool's Avatar
hmm i searched and didn't find anything. i'll keep looking thanks! anyone else?
Old Nov 19, 2007 | 11:52 AM
Default Re:
https://honda-tech.com/zerothread?id=907985
Old Nov 19, 2007 | 12:19 PM
Luserkid's Avatar
Default Re: Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=907985 </TD></TR></TABLE>
Thats how we do it, never had a problem.
Old Nov 19, 2007 | 02:14 PM
ejoner's Avatar
Default Re: Re: (Luserkid)
Yes that would work if you don't have a press, actually we've never used a press to install studs we always just pull them threw. An old socket with a washer works well as a spacer btw.
Old Nov 19, 2007 | 04:35 PM
em96civicex's Avatar
Default Re: Re: (ejoner)
On the how to, it says that you might damage your wheel bearing with that method. How likely is that? I need to replace a broken wheel stud.
Old Nov 20, 2007 | 07:29 AM
timmy0tool's Avatar
thanks for the replies guys! this will work.
Old Nov 20, 2007 | 08:52 AM
Luserkid's Avatar
Default Re: Re: (em96civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em96civicex &raquo;</TD></TR><TR><TD CLASS="quote">On the how to, it says that you might damage your wheel bearing with that method. How likely is that? I need to replace a broken wheel stud.</TD></TR></TABLE>
Only way i could see possibly damaging the bearing is if you put the hub on the bearings in a way to damage it. If you have your axle in then you wont damage it, just make sure to grease it up really good before you put the hub on.
Old Nov 21, 2007 | 07:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Only way i could see possibly damaging the bearing is if you put the hub on the bearings in a way to damage it. If you have your axle in then you wont damage it, just make sure to grease it up really good before you put the hub on. </TD></TR></TABLE>
Thanks for the reply! Its probably a dumb question, but is there any way the axle would come out? Any specific grease that I should use?
Old Dec 19, 2007 | 03:25 PM
timmy0tool's Avatar
Default Re: alternate way to installing arp extended studs (timmy0tool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy0tool &raquo;</TD></TR><TR><TD CLASS="quote">i know a press is ideal when installing arp extended studs but is there another way to do it?
i know you risk stripping the knurls off the stud but wouldn't that work?!</TD></TR></TABLE>
did it this way and it worked perfectly. just make sure to use a grade 8 nut!
JSA
Honda Civic (2006 - 2015)
Apr 7, 2011 02:05 AM
Importcustomx
Jan 14, 2008 11:44 AM
Jonathan_ED3
Apr 17, 2005 12:56 PM
Flamenco-T
Nov 1, 2002 08:23 PM
