header question!!
Old Nov 19, 2007 | 09:55 AM
skUnK2jdm's Avatar
Default header question!!
whats up peoples!!!
i got a question will aftermarket headers for a ls motor fit a b16??
Old Nov 19, 2007 | 10:42 AM
Padawan's Avatar
Darth ModerVader
Default Re: header question!! (skUnK2jdm)
Yes, but the flange at the cat is positioned at a different angle.
Old Nov 19, 2007 | 10:44 AM
skUnK2jdm's Avatar
Default Re: header question!! (Padawan)
oh i see so i will be visiting a muffler shop then!
Old Nov 22, 2007 | 02:04 PM
skUnK2jdm's Avatar
Old Nov 22, 2007 | 02:06 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but the flange at the cat is positioned at a different angle. </TD></TR></TABLE>
+1
the header will bolt on.but the problem is the downpipe flange. i had a muffler shop done that for me.
Old Nov 22, 2007 | 02:13 PM
96teggylsse's Avatar
Default Re: header question!! (crazyguy)
will work but you will have clearance issues now cause the ls header is made for a taller 1.8l as opposed to the shorter 1.6... you will see what i mean when you put it on. but yea you can make it work... not worth it in my opinion though
Old Nov 22, 2007 | 02:19 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">oh i see so i will be visiting a muffler shop then! </TD></TR></TABLE>
Chain muffler stores like Midas tend to screw you. Take it to a regular garage/shop that will do exhaust welding, you usually have better results there...
Old Nov 22, 2007 | 08:25 PM
skUnK2jdm's Avatar
Default Re: header question!! (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse &raquo;</TD></TR><TR><TD CLASS="quote">will work but you will have clearance issues now cause the ls header is made for a taller 1.8l as opposed to the shorter 1.6... you will see what i mean when you put it on. but yea you can make it work... not worth it in my opinion though </TD></TR></TABLE>
dam thats sucks
Old Nov 22, 2007 | 08:27 PM
Padawan's Avatar
Darth ModerVader
Default Re: header question!! (96teggylsse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse &raquo;</TD></TR><TR><TD CLASS="quote">will work but you will have clearance issues now</TD></TR></TABLE>
What kind of "clearance issues" are you referring to?
Old Nov 22, 2007 | 08:34 PM
19ekcoupe96's Avatar
will b16 headers fit on a b18?? jw
Old Nov 22, 2007 | 08:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: header question!! (19ekcoupe96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19ekcoupe96 &raquo;</TD></TR><TR><TD CLASS="quote">will b16 headers fit on a b18?? jw </TD></TR></TABLE>
That's the situation where you can indeed run in to a problem with clearing the oil pan, depending upon what specific header you're using. The flange at the cat is also angled differently.
Old Nov 23, 2007 | 03:15 AM
skUnK2jdm's Avatar
Old Nov 23, 2007 | 03:36 AM
spock_rocker's Avatar
memoryFAB.com representative
i actually have a B16 5zigen header that bolted right to my b20z with no issues, but i could be under the wrong assumption that all B series headers will fit all B series blocks
Old Nov 23, 2007 | 03:40 AM
skUnK2jdm's Avatar
Default Re: header question!! (spock_rocker)
wanna sell it!
Old Nov 23, 2007 | 07:54 AM
Cln94EG1's Avatar
This guy is right the B16 is a shorter block the a b18 im sure it will work it will just hang down more just watch for driveways. If your doing it the other way im not too sure if it will im sure it would it might just huge the oil pan
Old Nov 24, 2007 | 06:36 AM
in a couple months yes
HondaRcB
Nov 26, 2006 09:34 PM
Honda Crx
Feb 21, 2006 11:21 AM
blowbyu24
Nov 14, 2005 01:55 PM
jfingers
Jan 4, 2005 12:33 PM
fanatic
Nov 17, 2004 04:03 PM
