engine reving
I just did a swap on my 99 Honda accord putting a f20b in it, my engine is reving from 1500 to 3000 rpm, i change the map, tps clean my intake and check all my vacuum hoses and end up with nothing.... is there anything else i need to check?????
Search for a thread on here regarding the Cleaning of the IACV, FITV and TB (the title is very close to that)
You take off the FITV, tighten down a threaded valve thing, take off the IACV and clean it out, use carb cleaner or what not and clean the TB and then flush the coolant.
illicit^
May 20, 2007 07:06 PM
