5th Gen Base vs. Type SH Radiator
Old Nov 19, 2007 | 05:55 AM
Ricearonie's Avatar
Default 5th Gen Base vs. Type SH Radiator
Hey all,
i was hoping someone could confirm my answer but is there a difference between a base radiator and a type sh radiator? i've heard no because in the type sh the atts oil cooling lines come into play.
next question would be can a base radiator be modified to fit for the the type sh.
thanks.
Old Nov 19, 2007 | 06:13 AM
117's Avatar
117
A base radiator drops right into an SH, but you'll need to use an external stand alone cooler for the ATTS unit.
Old Nov 19, 2007 | 06:30 AM
97BB6Type-SH's Avatar
Default Re: 5th Gen Base vs. Type SH Radiator (Ricearonie)
yes its the same radiator. if you have a type-sh the lines will be there to hook them up to the radiator, if you have a base you just plug them up. its similar to an automatic car. you connect the type-sh lines to the same place you would connect the lines for an automatic tranny. except in the type-sh the lines are cooling the ATTS instead of the auto tranny. i just installed a new radiator on my SH and had this cleared up.
Old Nov 19, 2007 | 06:39 AM
Ricearonie's Avatar
Default Re: 5th Gen Base vs. Type SH Radiator (97BB6Type-SH)
you sir are a god amonst men. you just made my day.
thanks.
CuteAccord
Nov 24, 2009 11:24 PM
Tunerguy1989
Jun 2, 2009 06:39 AM
darkfx
Oct 5, 2005 04:04 PM
raylude
May 12, 2005 02:49 PM
bubs
Jan 31, 2005 03:17 AM
