highest offset + size wheels on 4th gens.
Has anyone tried 18x8 with +30 offset? I know it will fit with fender rolling... But has anyone had it with out fender rolling?
Oh and please dont give me the "learn to search" BS. Im running 17x8 with +30 offset and no rubbing on H&R sports; even though the guide for wheel sizing states it will rub.
i'd try and measure......
see if you have an extra 1/2" clearance on each side for the first thing.
then move your wheel to full lock and see if it would rub, the the other lock
then its a good idea to check while your suspension is under compression, and see if you have the room to fit another 1' of wheel. p.s. any reason you want to run an 8" wide wheel?
*****EDIT******
oops i read that completly wrong. with the right tire size you might be ok, but personally i think 17's are big enough. you'd have to run a 35 series tire and thats like a rubber band. good luck trying to miss EVERY pothole
*****EDIT******
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">
*****EDIT******
agreed. i'm running 215/45/17s and skunk2 springs. the ride is very stiff and potholes are my worst nightmare. so 18 inch wheels
*****EDIT******
</TD></TR></TABLE>agreed. i'm running 215/45/17s and skunk2 springs. the ride is very stiff and potholes are my worst nightmare. so 18 inch wheels
