FS: H22 Fully Build Block for Turbo *NEW* zero miles
LA IRON SLEEVE( original manufacture of darson sleeve)
H-beam Eagle RODS,
ACL bearing
87MM 9:1 CP piston, CP rings
micro-polish crank
it all assemble already, just need to put the gear and water pump and etc back together.
asking 2700 you will never find a fully built block this cheap with zero miles!
Modified by vietdragontekx at 4:57 PM 11/23/2007
H-beam Eagle RODS,
ACL bearing
micro-polish crank
golden eagle sleeved h22, SFP turbo manifold, h22 head, a1000 pump, studs, rods, pistons....56k no-w
ChrisRicketts
Dec 24, 2006 08:54 AM
