What tool to cut the plenum off an Intake manifold?
Old Nov 18, 2007 | 06:34 PM
RICE POLICE SIP's Avatar
Default What tool to cut the plenum off an Intake manifold?
What tool do people use to cut the plenum off of a stock IM? I'm thinking a band saw... If that IS the tool people use... Which one and what blade? TIA!
Shane
Old Nov 18, 2007 | 07:23 PM
MADMAX_zero's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (RICE POLICE SIP)
Vertical Bandsaw
Most bandsaws are setup for steel. I would crank the speed.
Old Nov 18, 2007 | 07:28 PM
hootiehoo's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (MADMAX_zero)
i always used a vert band saw and made some sort of jig to bolt the head flange to and slide it accross the blade for an even 90deg cut. a quick pass on a mill or even just a belt sander made it good to fab on. As to what blade, you can get away with using a steel blade, but it will take longer than if you used an aluminum blade. the difference is that steel blade will have more teeth, and they will me smaller. aluminum would have longer teeth, and you can run the speed faster. and finally wood would have even longer, less teeth and you can really run it fast.
during times when i did not have a band saw, i used a sawzall. simply use like 6in c clamps and clamp the head clange to a table. then use the saw and hack it off.
its actually faster than the band saw. Oof corse your cut will not be even, and youll need to spend much more time with the sander or cut off wheel to make all the runers even.
if times are real tough, just put one foot on the plenum and hack at it with a hack saw. its a bitch, but it works.
Old Nov 18, 2007 | 07:50 PM
bigTom's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (hootiehoo)
Any cutting i have to do on intake manifold I use a vertical bandsaw, 1/2" -18tpi blade and 1400fpm... cuts great! clean it up on the belt sander and you're good to go!
Old Nov 18, 2007 | 10:26 PM
.RTErnie's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (bigTom)
bah... you're all pussies. I use a sawzall
Old Nov 18, 2007 | 10:48 PM
ROTARY's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (.RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">bah... you're all pussies. I use a sawzall </TD></TR></TABLE>
sawzall.... DREMEL with a cutting disk FTMFW
Old Nov 19, 2007 | 02:44 AM
robbbby's Avatar
I ran mine through my bandsaw positioned vertically, went through really easily.
Old Nov 19, 2007 | 06:44 AM
autosport7's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (robbbby)
I just did mine this weekend and cut it off with the sawsall and then brought it to my friends work and used the mill to straighten them out
no matter how I have ever cut them I have always finnished them on the mill
Old Nov 19, 2007 | 10:15 AM
racecar chassis builder's Avatar
* B A N N E D *
Default Re: What tool to cut the plenum off an Intake manifold? (autosport7)
Any saw that will cut wood will cut aluminum.But one of those craftsman vertical wodd bandsaws with 8 or 6 teeth per inch cuts alum.like butter.
Old Nov 19, 2007 | 10:20 AM
Finest's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (ROTARY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">
sawzall.... DREMEL with a million cutting disks FTMFW </TD></TR></TABLE>
Fixed it for ya.
Old Nov 19, 2007 | 11:44 AM
k24em2's Avatar
Default Re: What tool to cut the plenum off an Intake manifold? (Finest)
if you get the fiber reinforced cutting disc for the dremel it'll last a bit longer, lol
Old Nov 21, 2007 | 05:59 AM
Default Re: What tool to cut the plenum off an Intake manifold? (k24em2)
Thanks for all of the replies... I was thinking a vert. band saw but just wanted to confirm w/ everyone else... THanks again!
Shane
HellaFab
Welding / Fabrication
26
Mar 15, 2016 04:05 AM
mkehler
Jul 9, 2009 09:48 PM
RJ#9
Jan 19, 2009 06:18 PM
Justin Olson
24
Sep 17, 2008 09:49 PM
Justin Olson
20
Jun 10, 2006 08:54 AM
