What timing belts are people using
Old Nov 18, 2007 | 05:53 PM
turbolshatch's Avatar
Default What timing belts are people using
WHat kinda timing belts are you guys using on your cars?> THe reason I ask is because I has a Honda timing belt on my built all motor gsr and it snapped on the highway today. The belt was just over a year old and had about 20 000km on it. I was just cruising at about 4000rpm in 5th gear and boom the car shut of. so i know all my pretty little valve will be jamed into my nice head
Modified by turbolshatch at 10:10 PM 11/18/2007
Old Nov 18, 2007 | 05:58 PM
miller's Avatar
Default Re: What timing belts are people using (turbolshatch)
OEM timing belt
Old Nov 18, 2007 | 05:59 PM
1 2 NV's Avatar
Default Re: What timing belts are people using (miller)
there is nothing that can take place of OEM.
Old Nov 18, 2007 | 06:00 PM
Johnny O A20 KIller's Avatar
OEM belt for me
Old Nov 18, 2007 | 06:20 PM
thats what I thought I guess it was just bad luck on my part. I thought it would have lasted longer then 20000km
Old Nov 18, 2007 | 07:08 PM
Garage 808 Hatch's Avatar
your belt could have been too tight?
i also use OEM
Old Nov 18, 2007 | 07:13 PM
paulzy's Avatar
OEM or Gates. If I remember correctly, gates manufactures the OEM belts.
Old Nov 18, 2007 | 07:22 PM
reaction360's Avatar
Default Re: (paulzy)
I run a Gates belt.
Old Nov 18, 2007 | 07:46 PM
IN VTEC's Avatar
GS-R cams with OEM Honda belt.
Skunk2 Pro2 cams with OEM Honda belt.
Old Nov 18, 2007 | 07:49 PM
Runnerdown's Avatar
Default Re: What timing belts are people using (IN VTEC)
Always used and preferred oem belts.
Old Nov 19, 2007 | 04:48 AM
jjspec's Avatar
Default Re: What timing belts are people using (Runnerdown)
I use Honda T belts FTW. Did you have an oil leak or was the belt too tight? Good luck with your head.
Old Nov 19, 2007 | 06:05 AM
tricura's Avatar
gates racing for us
Old Nov 19, 2007 | 06:30 AM
BoostedJeff's Avatar
Default Re: (tricura)
OEM Honda
Old Nov 19, 2007 | 06:46 AM
b19coupe's Avatar
OEM timing belts FTW
Old Nov 19, 2007 | 07:22 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: What timing belts are people using (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">OEM timing belts FTW </TD></TR></TABLE>
X2
Old Nov 19, 2007 | 07:31 AM
TheWickedOne's Avatar
OEM
Old Nov 19, 2007 | 08:17 AM
ciscoscivic's Avatar
Default Re: (TheWickedOne)
oem
Old Nov 19, 2007 | 08:26 AM
morgan@synapse motorsport's Avatar
oem
Old Nov 19, 2007 | 01:45 PM
Default Re: (mike@synapse motorsport)
Well I dont think it was over torqued and I dont have any oil leaks. But I pulled the head off today at work and there are atleast five bent valves that I could see. Oh well I guess its time to rebuild the head again and give the oem belt another try.
Old Nov 19, 2007 | 02:05 PM
bruised eg's Avatar
Default Re: (turbolshatch)
OEM, but you should check your belt tension with the engine hot, I pulled the guts out of a tensioner because the belt was just right cold but with the engine hot it was WAY too tight. I got lucky and only had to replace the idler, unfortunately you didn't get so lucky. Good luck with the rebuild.
Old Nov 19, 2007 | 02:12 PM
JDMisGOOD's Avatar
Default Re: (bruised eg)
OEM or Greddy timing belts for me.
Old Nov 19, 2007 | 04:24 PM
fast forward driver's Avatar
Default Re: (JDMisGOOD)
OEM
Old Nov 19, 2007 | 04:49 PM
A.E Motoring's Avatar
Default Re: (fast forward driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast forward driver &raquo;</TD></TR><TR><TD CLASS="quote">OEM </TD></TR></TABLE>
Old Nov 20, 2007 | 12:38 AM
ITR_Sol's Avatar
Default Re: (Dual Cam Racing)
OEM for me. TODA is a pretty blue oem. Gates does make oem.
Bet it was too tight. Make sure you had both od the "retaining washers" on the bottom pulley in place.
Old Nov 20, 2007 | 04:03 AM
sagaboy5983's Avatar
OEM for me
