Priming my bumpers
Old Nov 18, 2007 | 05:17 PM
trepteg's Avatar
Default Priming my bumpers
hi !
I hearded that I have to use a special primer for my bumpers and sides skirts , it is true ?
it yes , what kind of primer should I use for the bumper ? and what kind for the rest of the car ?
I red in the post-it topic that the epoxy primers are the one that are like OEM primers .. should I use this ?
thanks for your awnsers !
Old Nov 19, 2007 | 01:20 PM
alltech_hybrid's Avatar
Default Re: Priming my bumpers (trepteg)
use a flex agent or some bulldog and your good
Old Nov 19, 2007 | 04:57 PM
powerflow's Avatar
Default Re: Priming my bumpers (alltech_hybrid)
Yep, use a flex agent if you want long life, maximum flexibility without cracking on flexible parts. Some high quality paints are quite flexible without it, but using it will unsure longevity. Flex agents can be used in the primer, base and clear if applicable. Raw plastic adhesion promoter should also be used. Your better off using product together from the same paint system if your not experienced with mixing different products.
chrisff521
Paint and Body
Mar 4, 2010 06:23 AM
on-site ej1
Paint and Body
Aug 28, 2009 12:56 PM
mikeaitken
Paint and Body
Mar 8, 2008 12:21 PM
msinsky14
Paint and Body
Oct 16, 2007 01:57 PM
